Results 1 to 8 of 8
Thread: Best AG pump??... Anyone??...
    Jul 2011
    Florida
    5
    Hello everyone, I have an 18' X 52" AGP. My pump is not working propertly, the mechanic told me that the impeller is broken and the fix will cost me almost half of the cost of a new pump so I decided to buy a new one. My pump is a Waterway Clear Water II 100sqft Cartridge Filter System with 1.5hp Pump 2 speed. My question is... should I buy the same pump or is there a better pump than this one on the market? Please I need your advise asap. Thank you.
    7,646 Gal.Trevi Ultima Series 222 - 18ft Round 52" Resin / Galv. Steel Above Ground Pool - Waterway Clear Water II 100sqft Cartridge Filter System with 1.5 hp Pump 2 speed
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Best AG pump??... Anyone??...
    I think I would likely get a second opinion an impeller should be $30 or so unless it is a discontinued model, etc. Do you know the model number of the pump?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Pentair or Hayward are very popular brands...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jul 2011
    Florida
    5
    Update: Hello! So as you can read we decided to get a new pump and we purchased the same model we had, Waterway HI FLO SD-15-2N11CC. My husband installed it and primed it but it seems that it doesnt flow enough water and the filter is getting air. The worse part is that my pool is green and I poured a jar of clorine thinking that the pump was working well. Any ideas why this is happening?
    30,403
    You have a suction side air leak. Somewhere between the pump and the skimmer(s), air is being sucked into the system. Find that leak and your issues will be solved.
    Jul 2011
    Florida
    5
    Thanks for your respond but.... How do I find leak .... Is it in the PVC?... Sorry but I have 0 knowledge in this matter.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Did ya' lube the new O ring on the pump basket?.....
    Jul 2011
    Florida
    5
    Oh no We didn't. After I told my husband a repair man was gonna charge us $70.00 for the repair he is thinking of changing all the PVC lines from the skimmer to the pump.
