Results 1 to 10 of 10
Thread: Pressure problems
    Pressure problems
    Hi all. Opened up yesterday. Was a heavy winter in New England, so water was not as clear as prior years. Spend a lot of time pulling leaves, etc out of the pool before start up. Started up and all systems appeared to be working well. After a few hours, filter pressure went up to around 30 psi and our Paramount water valve pressure would drop from the required 20 psi to 10 (and lower). Have back washed twice, after each time filter pressure goes to normal (28 psi) and Paramount SwingJet water valve goes up to 20, but again pressure continues to drop after running for awhile. Water is clearing, but still needs to be vaccumed and cleaned up some more. Am I losing pressure because of this and need to continue back washing (and vacuum) or is there something else going on that's causing the pressure in filter to climb and water valve to drop significantly? Thanks!
    10k gallon fiberglass freeform pool, Paramount SwingJet system, Dolphin DX5 robot, Pentair 48" Tagelus sand filter with glass media, WhisperFlo 1 HP pump, Hayward H200FDN natural gas heater, TF-100 Test Kit, and, of course, Margaritaville Tahiti blender!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pressure problems
    It sounds like the filter is doing its job, how long are you backwashing each time, it seems many people do not back wash for long enough, so I am just guessing this might be your issue.
    Ike
    Hi. Thanks for the prompt reply. Haven't timed it, but would say backwashing for a min or so, until output is visually clean looking. Sight glass is clear too.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok it sounds like that is not the issue then, and the filter is just doing its job.
    Hmmm, ok, had hoped it might just be an iterative process since the water is still clearing up. Since pressure returns to normal after I backwash, I'm thinking its not equipment related (as I would think if it were, pressure wouldn't ever get up to normal). Any thoughts on what it could be?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You may have something trying to grow in your water, do you have current test results using one of the suggested kits, and have you don't an overnight chlorine loss test?
    Hi. I have not tested yet as I just opened yesterday afternoon. Will do that tomorrow. I know I should be running 24/7 after opening, but a, concerned that running with the pressure not correct is bad, so have not been. Assume this is the right approach?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You want to backwash when needed and not let the pressure get to high, but without knowing levels, and not having any chlorine in it chances are you are going to be loosing any headway you might have made as things can start to grow fast in an open pool if the water is warm enough. Step one should be getting the pH right, then since the water is not clear, you need to start the SLAM process and continue until it is clear and you have no excess chlorine loss
    Hi all. Sorry for the delayed reply, the rest of the weekend was crazy busy. Anyway, did another backwash Sat morning (and vaccumed) and the pressure has been spot on since then. Appreciate the help!
    May 2013
    Needham, MA
    140
    Domo, please check your inbox for pm.
