Thread: IC40 intellichlor
    May 2014
    MIDDLETOWN DE
    3
    IC40 intellichlor
    noticed today my no flow light is red. checked my pump and it is fine flow is good to the jets in the pool. started up pool about 2 weeks ago and had no
    problems. the generator is about 5 years old never had any problem. any ideas what is wrong.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: IC40 intellichlor
    Try checking to see if the flow switch is working. Intellichlor IC 40 Red No Flow Indicator
    Love TFP? Become a
    TFP Supporter!
    May 2014
    MIDDLETOWN DE
    3
    Thankyou ; I did remove it from the unit and held the prongs together and the light stays red; did noticed that the salt light run up and down like when you first
    turn the unit on. is the flow switch serviceable.
    You need to replace the flow switch as a whole. Replacement flow switches are readily available.
    May 2014
    MIDDLETOWN DE
    3
    Thank you didn't know that the flow switch was serviceable by itself; order one and replaced it and it took care of my problem ; again thank you I was about to
    replace the whole generator ; if you need any help with cars free to ask.
