Thread: testing fc question
    May 2014
    hope mills, nc
    18
    testing fc question
    I know I need to shock to 20 but I have a taylor 2000 kit ( I purchased wrong one by accident and then purchased additional reagents separately so I have everything now ) however, my comparator only shows numbers/color chart 0-5 on it how do I know if I have reached 20? Maybe im missing something...im sorry but thanks so much, in advance.
    Above ground 24ft round 54 in deep 1hp 2speed Hayward power flo matrix pump& sand filter.
    Re: testing fc question
    You need the FAS-DPD chlorine test to measure levels around 20. The reagents it uses include R-0870 & R-0871.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If you have the FAS-DPD reagents, you need one of these. DPD powder is R-0870, and FAS is R-0871. Not a color comparison.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    If you purchased the R-0870 and R-0871 FAS-DPD reagents, you don't use the comparator. Use a vial.
