Thread: New pool owner here trying to get my chemicals right
    May 2014
    Commerce, OK. United States
    3
    I just bought a 18 ft by 4 ft Intex pool im trying to figure out my chemicals. I tested my tap water which is what im filling the pool with to see what chemicals were already there from the city treatment, i used a Pool Master 5 way test kit until my TF100 gets here they are
    FC- 0
    CC- 0
    PH- 7.2
    TA- 0 as far as I can tell
    Salt- 200 ppm
    Using pool math to get at recommended levels I would need to add
    FC -63 oz bleach at 6 %
    PH- 1.8 oz washing soda
    TA- 100 oz baking soda
    CYA- 74 oz stabilizer
    Salt- 178 lbs
    Would that be correct or am i reading that wrong i dont want to end up buying way to much or not enough of something. Any help would be great thanks.
    Intex Ultra Frame 18 ft round 48 in deep and 7,600 gallons, pool surface vinyl, Krystal Clear Cartridge Filter Pump with 1,500 gph, Krystal Clear SWG. Located in North East Oklahoma.
    Re: New pool owner here trying to get my chemicals right
    Welcome to TFP!
    Adjust the TA first and then retest the PH before adjusting the PH. Raising the TA will likely raise the PH a little.
    Add 2 ppm of chlorine this evening after sunset, and then switch to aiming for your FC target level next time
    Also, don't raise the CYA all in one step. It is easy to raise CYA, but tricky to lower CYA. So aim for something below your real goal, and then adjust up based on retesting in a week.
    May 2014
    3
    Ok thanks, but are my amounts to raise it correct? Im horrible with math and all that.
    Your math looks reasonable, just make the adjustments I suggested and you will be fine.
    May 2014
    3
    Thanks alot i appriciate the help.
