Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: New pool build!
    Mar 2014
    Annapolis, Maryland
    37
    New pool build!
    Building a new pool in Maryland.
    First we had to take out the big oak tree...
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    The stump was go big it had to be ground up...
    Lucky for us the kids were off from school the day the bulldozers came. It was really fun to watch the pool take shape.
    The bulldozer wasn't able to break up or fit the tree root ball in the dump truck, so it was left in our yard.
    The deep end will be about 9 feet and is off on the right...
    Here's the deep end; it has a seat in it, and the pool wall will be raised on one side with a fountain coming out of it so the kids can jump off (instead of a diving board). Sorry I don't know the correct terminology for this thing! The decking around it will have a step up on that end.
    Shallow end to deep end...
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: New pool build!
    Looks like you're making solid progress.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    So you can see on the left in the shallow end will be a "sun shelf" which is really just a big huge step. We decided to put that there for our big 100 lb. dog to get in and out more easily.
    So everything was going very quickly with the pool build; a few days later, a rebar crew came and put the rebar in. And we were just waiting for the inspectors. But then the rain came...
    So they were calling for a good 2 inches of rain. The deep end started to puddle. Then it started to fill. I snapped this photo around 1pm:
    And by 3pm, it looked like this:
    Um, so this is NOT quite what I had in mind when I envisioned filling my pool up...
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    So the pool builder came out and put a pump in it, and after a couple days the water was drained from the pool. But the dirt walls turned to mud and slid down, covering the rebar in several passes. Inspector came out before pool was even drained and slapped a big "FAIL" sticker on our door.
    Here's a closer look at the mud...
    So the pool builder came back and said the failed inspection was no surprise, given all the water. And I guess now they're very behind (since all over our area pools filled up and they had to go around pumping them all). Next step is to send a crew over to "muck" out the mud so the rebar can pass inspection.
    Pool builder said not to worry about the dirt sliding behind the rebar...he said the concrete bonds to the rebar and it will be sturdy and solid even without the backfill...does that sound right?
    Next step is inspection and concrete/gunnite...
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    Here are the specs:
    30,000 gallons
    41Lx24W
    700 sq ft area
    5'6 tanning ledge, 6' deep end loveseat
    2' sheer descent
    500 sq ft paver patio and paver coping
    Chlorinator: Fusion Mineral System (which we decided to switch out for a salt generator)
    Sunstone Quartz pebble finish in blue pearl
    Jandy 1.5hp pump
    Polaris 360 pool cleaner
    Hayward Color Logic LED pool light
    ...so are we on the right track?
    Casey's Avatar
    SW PA
    10,418
    Re: New pool build!
    You don't need a mineral system so if you're getting it, get rid of it. It's a waste of money. You will turn every blonde haired beauty green. AND You'll stain your pool surface with unsightly metal stains. Do you really want to do all that?
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    Yeah, my daughter is blonde, so that mineral system is OUT. When the plumbers came, they did install it (they never got a change order), I called the pool builder and told him and he said he'll make the switch to the salt system (for an additional $1,200). Does that upgrade price sound right?
    Nov 2013
    Miami, FL
    348
    Re: New pool build!
    sorry to hear about the delay from the rain! It looks like it will be a great pool once it is finished.
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    Casey's Avatar
    SW PA
    10,418
    Re: New pool build!
    I'm not sure on the charge but glad to see you get rid of it!
    Re: New pool build!
    Congratulations! Looks like it's going to be a great pool! I think we are using the same pool builder... They also installed the Nature Fusion, but I also want it removed. What is the new system that you are switching out to? $1,200 sounds a little high though.
    Good luck with your build!
    MJ
    27,675 GAL IG Gunite pool, Jandy 2HP E Plus Pump, Nature 2 Fusion Soft salt water and mineral sanitizing system , Jandy CL460 Filter
    41 x 21', 740 sq/ft w/ 2 LED Jandy Water Colors Large, 18" Raised 8' Perimeter Spa with LED Jandy Water Colors Small, Jandy LRZ 400K BTU Heater
    Polaris 280 Clearner. 2080 SQ/FT Techo Bloc Blu 60 Decking with 424 face/ft Techo-bloc Mini Creta retaining walls with lighting.
    NEXT Purchase: TF-100 test kit
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    Quote Originally Posted by DCFan9 View Post
    I don't know what the salt system is...I need to call the pool builder today and ask him some questions. He is very lax on detail; the more I read on this forum, the more questions I ask him! I will report back today and let you know.
    They did hook up the mineral system, and left it in place (I guess so those pipes would be connected) until the salt system comes in. Waiting not so patiently for the gunnite!
    Apr 2014
    Enola, PA
    24
    Re: New pool build!
    Are you building with A & S. We are and we are hoping to not use the mineral part of the Fusion system, just use the Salt generation part of it.
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    Quote Originally Posted by mynewpool2014 View Post
    Yes, we are using A&S. The salt generator, I just found is, is a Jandy AquaPure. Upcharge of $1,200 if you switch it out with the Fusion system.
    Apr 2014
    Enola, PA
    24
    Re: New pool build!
    That is what I was quoted too, and we decided to just keep the Fusion, on this forum people have managed to use Fusion without the mineral cartridge and that is what we intend to do. Could not justify $1200 of what seemingly was the difference between the two units.
    Jul 2013
    Clarksburg, MD
    93
    Re: New pool build!
    Hey both..two more A&S folks...we also switched out for the Salt Generator....$1,200 in the long term isn't too much...I know we always have to balance these little 1K items or before you know it you've spent an additional 20K, but in this case I think the 1,200 is well worth it...just my 2 cents.
    As an FYI and example, my friend had their pool built by AS and didn't buy the heater to save on cost, well now a year later and the heater is going to cost 6K to add...If I recall it was 2500 when the pool was being installed (I could look it up but I'm lazy). Just pointing out some things are better to bite the bullet up front. As they say, Buy once Cry once.
    18k gallon IG Sunstone Pearl pebble finish pool, Jandy Aquapure 1400 SWG, Jandy 1.5HP VS E-Pump, Jandy 60sqft DE filter, Jandy Legacy Propane Heater, Polaris 3900 Robotic Cleaner, TF-100 w/ SpeedStir, Anchor Mesh pool cover
    Apr 2014
    Enola, PA
    24
    Re: New pool build!
    Is Nature Fusion Soft without the mineral Cartridge not the same as AquaPure without the capability to link with PureLink. That's what I thought, and the sales guy explained. I am not sure what it would cost me to switch now, Fusion system is already installed.
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    Hmm...I have no idea. What is PureLink?!? Just when I think I'm understanding the equipment...
    Quote Originally Posted by Omnipotent View Post
    I think you're right, that's why we're putting it in now. Question for you: I notice you have a Sunstone Pearl finish. What color is it, and how do you like it? The Sunstone website does a terrible job showing photos of the water color; we are considering the Blue Pearl but i'm worried it's going to be too dark. Any suggestions or photos?
    Jul 2013
    Clarksburg, MD
    93
    Re: New pool build!
    We went with Black Pearl and we wanted it dark...Pacific Ocean dark....almost went with a black bottom pool but thought this was dark enough. As for photos, your right we ended up just searching the net for black pearl photos and decided it was what we liked...that's the best advice I have for you on that one.
  20. Back To Top    #20
    Mar 2014
    Annapolis, Maryland
    37
    Re: New pool build!
    Well, after two rain delays we finally got concrete today! Yay!
    Hmm...anyone else think that the first step onto the sun shelf is way too dinky??? Looks more like a tripping hazard than a step.
    So, the concrete guys left and didn't leave me any instructions. Am I supposed to keep this thing wet? How many times a day do I water?
    Here's a photo of the "fun cascade" which is supposed to be a sheer wall with a fountain. I didn't realize they were setting it back from the edge of the pool...no clue how we're going to tile this part. That also looks pretty dinky, although I suppose once there is decking behind it and it's capped off with pavers it will look bigger?
