Thread: Pool opening - which hole in skimmer gets opened and leftover screws
    I had someone connect a new pump and I had thought they had verified everything else was food to go.
    1. I noticed water was leaking from bottom of sand filter, but I found a screw on cap, I didn't use any Teflon tape, just screwed it on and that worked.
    2. I saw the filter water screen bottle was there and I screwed it in, no Teflon.
    3. I plugged in the filter pressure Guage with teflon tape.
    4. What I think is remaining is the skimmer has two plugs in it, one white one which I'm pretty sure always stays plugged, can someone confirm this and why would it always stay plugged?
    The other hole has a black plug with teflon tape so it must have been when they winterized, so I'm sure I should remove it, can it be done by hand? Do I need a tool?
    5. I also found these 2 screws and I have no idea what they are for, in assuming for something on the filter buy I don't know what.
    Attached pictures, thanks!
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    38,548
    Re: Pool opening - which hole in skimmer gets opened and leftover screws
    Do you have a floor drain? If so is it plumbed to the pump?
    If no floor drain or it is plumbed to the pump, then likely the white plug does stay in the skimmer and you only remove the black one.
    The screws look like the drain plugs for the bottom of your pump.
    The pool has two bottom drains (regulation), I believe it is plumbed to the pump because I can open and close my bottom drain when vacuuming by opening or closing a valve.
    It is the valve parallel to my skimmer valve and both of those connect to one pipe feeding in to my pump.
    I attached the picture, does that mean I leave it?
    How do I remove the black one? Should I be able to do it by hand?
    38,548
    IF the drain runs to the pump, then likely one of the holes in the skimmer should stay plugged. I can not tell what the black one looks like to suggest how to remove it. Obviously it needs to be unscrewed, just not sure with what.
    BTW, you are going to run out of picture space soon, so check out: How To Post Pictures
    Thanks for the help, I was able to remove it with a wrench (the black one) and I left the white one in place.
    I noticed some of the seal around the white one was coming off, after closing it I guess they sealed it with a silicone. What's the harm if water is able to get in there?
    38,548
    Depends on what is under the white plug. It may be an open hole which would mean you would be loosing water if the plug leaks.
