Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: what do i need to meassure?
    Apr 2014
    lousiana
    105
    so guys i use a baby bottle to measssure out the ammount of bleach i need to add to my pool but, is there there something better? i use the baby bottle cause it has ounces 1 - 9 on it, other things i found skip numbers by two......so whats better or what do you guys use? thanks so much
    2 year old 14x48 intex ultra frame
    intex 633 pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: what do i need to meassure?
    That's as good as anything else if you can measure up to how much you need per addition with it to reach target level.
    Jun 2013
    Newcastle, Oklahoma
    508
    i use one of the wife's old measuring cups that she never used because it was graduated in ounces instead of cups....
    you can get a decent measuring cup in the Housewares section at walmart for a couple bucks. it would be a lot easier than a baby bottle. just make sure its in ounces.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    this is what I use. Glass measuring cup. And Ball Jar. You can find these at WalMart
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Apr 2010
    East Texas
    9,572
    Mason jars should only be used to measure beer or shine!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I use glass here too, a 32 oz version. Just don't drop it on the cement/pavers!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I use a plastic measuring cup I bought at the -gasp- pool store. Unbreakable. Plus I can read the graduiations from the inside out from above, when I'm holding the acid jug far away from my face.
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Quote Originally Posted by gtnos View Post
    I think I paid all of $1 for a plastic measuring cup from WalMart that is marked in single ounce increments up to 40oz. I can't fathom measuring out acid additions into a baby bottle...
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    I vote for the plastic measuring cup from Walmart. I'm not allowed to have glass in the pool area as I am a certified clutz.......I can produce evidence of that certification.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    My only worry about plastic was if muriatic acid would have any issues in it. Since there are different types of plastics I wasn't sure.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I use a 2 1/2 cup plastic measuring cup. I was having a hard time seeing the lines on the side so I just used a sharpie to make a mark at 10 and 20 oz. I usually add 20-25 oz. When I need 5 I just eyeball it between the 4 and 6 oz. I think I usually end up with 26 oz when I do that.
    I added a step though. I keep my bleach in the kitchen and measure it out in there so instead of trying to carry that small cup of bleach, I set it in my special bleach bucket! (It's a pretty pink bucket I got on clearance at target because I like to buy stuff.)
    If I need more than 20 oz I measure the smaller amount (usually 5 oz) dump it in the bucket then measure the 20oz and just sit the cup (full of 20 oz) in there and carry the bucket to the pool. I use the cup to pour it into the pool because it makes a nice small stream so I don't add to quickly.
    Main reason for the bucket is so I don't risk spilling the bleach on me when I'm walking out to the pool. I'm sure the one day I only need 20oz and I try to walk with that cup full I'll trip on something stupid and bleach will go everywhere!
    *edit* I've never had to use acid before so I don't know about what I'd use for that!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    508
    Quote Originally Posted by steveg_nh View Post
    Wondering too because I bought a plastic one to use this year.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I've got dry and liquid acid in plastic containers.... I do believe its a special non corrosive plastic.... HDPE I think?
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Apr 2014
    lousiana
    105
    all good ideas its just on a lot of things it jumps from 10 oz to 15 or 20 oz.....i hate having to eyeball things is all
    intex 633 pump
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Quote Originally Posted by queeniepaula View Post
    4 oz of acid changes my ph by 0.04-- I don't sweat an ounce or 2. 7.4, 7.5, 7.6 so what?
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Smykowski's Avatar
    Sep 2011
    3,065
    Cheap plastic measuring cup from Target for me. No issues.
    I haven't seen anyone say it, and I hope it would be obvious, but rinse that cup out really, really well with pool water in-between chemicals. You never, ever want liquid chlorine to come in contact with muriatic acid.
    Apr 2014
    lousiana
    105
    thanks for the link....i like the idea of this jugIMG_4045_opt.jpg guess ill have to look up in pool math how much bleach gets me to 1 ppm, 2ppm and so on huh and put that on the side of a jug....guess a gallon water bottle would work btw i forgot is 4 or 5 ppm the target FC? and what happens if at some time i might be at 6 or so? im guessing its not a huge deal cause 10 and more is shock level right?
    intex 633 pump
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by woodyp View Post
  20. Back To Top    #20
    Jun 2007
    New Jersey
    653
    I don't get why you people think in ounces (exception for DaneCE--kudos!). What a waste of time. Use ppm. I always use 12.5% LC so I use a DE scoop that is marked in ppm FC. 1 ppm FC for my size pooll is about an inch down from the top. The mark is a scratch, because LC will bleach out any known marker. MA comes in one gallon bottles. On my size pool, one-third of a bottle corresponds to one drop of acid demand reagent in the Taylor system which nobody on here uses but I prefer. Never need to calculate for FC and MA--just do it once and as long as your pool size and chem concentration doesn't change you never do it again. KISS. I save PoolCalc for my Sunday check of all chemicals.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
