Thread: Adding Borates!
    Adding Borates!
    I am going to try Borates in the pool this year!! Just FYI I ordered 50 lbs from dudadiesel for $89.90 free shipping. That was cheaper than even going the borax and acid method and from what I understand I just pour it in the pool?? Any advise is welcome!!!
    23k gal IG Vinyl Liner
    Sand Filter Pentair Pump VS
    Electric Heat Ft Wayne Indiana
    Built 2012
    Re: Adding Borates!
    Yep, just scatter it around the surface of the water, and run the pump for at least the next hour. The PH will go down just a little, not usually enough to matter.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Adding Borates!
    I'd add about 3/4 of what you think you'll need then wait a day, measure, top off.
    I couldn't be happier with adding using boric acid from Duda...
