Results 1 to 11 of 11
Thread: Ladder Removal
    May 2014
    Wilmington,NC
    5
    Ladder Removal
    I have an inground pool. I had it installed about 2 years ago. This is the first time I've needed to remove the ladder in the deep end. I started by lifting the domes on the legs, and removing the long bolt that was going into the concrete. I tried wiggling and lifting up on each side, also had a helper assist, but it didn't even move. The legs in the water came up a bit, but that was it.
    Is there something I am missing? Is there a release, or something that I am supposed to be pushing? Looking into where the bolts came out of, I can see a white round piece, which I guess attaches to the cup, but nothing that is holding.
    Thoughts? Thanks!
    Casey's Avatar
    SW PA
    10,461
    Re: Ladder Removal
    Welcome to TFP! Although I can not assist you, someone should be around soon to help!
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Re: Ladder Removal
    What you did is everything needed to remove the ladder from my own inground pool. I just loosen the bolts and pull the ladder up. The bolts essentially close a clamp the holds the ladder.
    I would say try a rubber mallet, as it's probably just stuck, but am hesitant to officially suggest that until and unless at least one pool professional here (Jason?) agrees with me.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    30,432
    Re: Ladder Removal
    I am not a pool professional but I need a rubber mallet with mine. I have to hit it harder than I really like to, but you can eventually wiggle it loose.
    Re: Ladder Removal
    The bolts pull up a wedge that locks the rail in place. Put the screw back in a few threads and tap it down to push the wedge down.
    Support the site
    rhaas12321's Avatar
    Jul 2012
    Sunny Southern Oregon
    41
    Re: Ladder Removal
    Quote Originally Posted by JamesW View Post
    That and I had to unbolt and remove the 3 stairs so I could twist each rail back and forth to remove mine. But they may have been there since the pool was built in '83. I bought it in foreclosure 4 years ago.
    10k Gallon, IG Kafko Vinyl Liner (8/1/12), 200# Sand w/ 1 hp Hayward MaxFlo pump, Taylor K2006
    3 4x12 Heliocol East facing + 3 4x12 Heliocol West facing 2015
    Robert from Sunny Southern Oregon
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Ladder Removal
    This is what you need to do. Loosening the screw leaves the wedges pulled up tight. A little tap pushes them down and loosens them.
    Casey's Avatar
    SW PA
    10,461
    Re: Ladder Removal
    Hi jimi... Just stopping in for an update to see if you removed your ladder?
    May 2014
    Wilmington,NC
    5
    Re: Ladder Removal
    Thanks for checking in. I can get one side to come up, but the other side won't move. It will wiggle a bit, but other than that, no movement. I wonder if when it was installed some concrete got in the leg? I thought they set the legs after it cured, but just wondering.
    Quote Originally Posted by Casey View Post
    30,432
    Re: Ladder Removal
    tap it with that rubber mallet while you are wiggling it and lifting upward.
    May 2014
    Wilmington,NC
    5
    Re: Ladder Removal
    Thanks, I tried that this morning before work, and the one side just will not move. You're in Raleigh... come down to Wilmington and give me a hand! haha
