Thread: Priming Pool Pump
    May 2014
    Cincinnati
    2
    Priming Pool Pump
    Hello!
    I just opened my new pool for the first time last week. Everytime I turn off the pump and turn it back on it takes about a half an hour to get back the proper flow of water. I have tried filling the area with the basket up with water but it just sucks it through.
    Am I doing something wrong?
    Thanks!
    20,000 Gallon Pool, Inground,Vinyl,Sand Filter
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Priming Pool Pump
    You probably have a suction side air leak. Read this article.
    http://www.troublefreepool.com/conte...side-air-leaks
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    May 2014
    Cincinnati
    2
    5. The pool water level.
    Pump running, visually inspect the skimmer to make sure absolutely no air is "whirlpooled" down into the skimmer. That's a fairly common cause and an easy fix....add more water to the pool and make sure that the weir (flapper) door operates correctly.
    I have noticed this!
    Thanks!
