Thread: Need help with Baker sand filter
    Are there any tips on how to get the dome lid off the top of a old Baker sand filter? The cover appears to be a synthetic material of some type with 4 fins on top. I just broke the fins off trying to get into the filter. I need to replace the lower outlet gasket.
    If times were better I'd replace the filter, but I'd like to keep this one going for a few more years. I replaced the motor and pump about 2-1/2 years ago and at the end of last season I had to replace the bearing in the motor; seems like the new stuff doesn't last.
    20 x 40 Vinyl, w/ Pentair 1 hp pump & Hayward 24" top mount filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Need help with Baker sand filter
    Any chance you can post a picture of what you have? Google leads me to a single picture of a lid with fins on it, and a site selling gigantic commercial filters.
    Let me get one and I'll post it.
    I had the cover off about 2 weeks ago, it was put back together using super lube on the mating surfaces and O ring.
    Since I broke the fins off, I am trying to add some grip points by attaching 2 aluminum squares to the top using epoxy. The epoxy is still setting up so I don’t know how successful the glue will be.
    The epoxy set and I attempted to put some pressure on the squares to unscrew the lid. The epoxy is stronger than the lit material, the squares popped off with a little of the lid material still attached. Unless someone has a better idea, my next step is to drill 4 holes and tap them for some bolts. After (if) I get the lit off; I'll thread them from the inside with some gasket material.
