Thread: Cartridge Filter Leaking on Startup
    Mar 2014
    Orlando, FL
    35
    Upon pump start up, my cartridge filter leaks for about 10 seconds then completely stops. I've used a health amount of magic lube on the O ring, and that seems to help a little. Not sure if this is normal or not (I suspect that it is not.)
    Is it time just for a new O ring?
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cartridge Filter Leaking on Startup
    Does the O ring appear to have stretched? If so then yes, probably replace it.
    Mar 2014
    Orlando, FL
    35
    Its pretty snug, takes some effort it get it back on. I'll try replacing it and see what happens
