Results 1 to 9 of 9
Thread: 1st water test; New Fill; 1st time pool owner
    May 2014
    Virginia Beach, VA
    56
    My very first pool is installed and should be finished filling today.
    Since the water level is now within reach, I did a complete test of it with my new TF-100 kit
    Here are the results; assuming I did everything correctly:
    FC: 0.5
    CC: 1.5
    TC: 2.0
    CH: 50
    TA: 40
    PH: 7.2
    CYA: 0
    The bleach that I bought and will be using is the store brand from Target. Its regular bleach, 121 oz jug and says Active Ingredient Sodium Hypochlorite 8.25%, Other Ingredient 91.75%, Yields 7.86% Available Chlorine-----is that the number I should use in PoolMath (7.86%)?
    Trying to determine what I will need to add to my water once its full and ready.
    Thanks
    24' Round Above Ground - 13,500 gal, Cartridge Filter, Installed on 5-7-14, First Time Pool Owner! TFP True Believer!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,012
    Re: 1st water test; New Fill; 1st time pool owner
    Plug 8.25% into Poolmath.
    While you're at Target, pick up some Borax and some Baking Soda to raise pH and TA a little. I'd target 7.4 pH and 70 TA. If you overshoot a little because the pool volume is slightly off, it's no big deal. If you undershoot, it's easy to add more.
    May 2014
    Virginia Beach, VA
    56
    Roger that. Thanks Richard
    38,301
    You also need to add 30+ppm of CYA ... you can find the stabilizer/conditioner at Walmart.
    I think I would skip the borax and just raise the TA some with baking soda, pH will generally climb on its own.
    May 2014
    Virginia Beach, VA
    56
    ..and just to be clear, I put the CYA in a sock in the skimmer and leave it alone until its empty, correct?
    If that is right, after its dispersed, how long do I wait until I retest CYA?
    38,301
    If you leave your pump on 24/7 that is fine. Or hang it in front of the return jet. Give it a few squeezes every so often.
    Once it is dissolved, assume it is active (to determine your FC levels), but do not test for a week.
    May 2014
    Virginia Beach, VA
    56
    Ok, thanks. One more question about PoolMath, since I have 0 CYA, its only computing a "goal" of 1-3ppm FC for me. Is that right? It only because I have no CYA. Should I instead add the correct amount of bleach for a "goal" of 5 FC instead?
    38,301
    Until the CYA is in the water, just keep the FC up to around 2ppm. As it dissolves, you can raise it up to 5ppm.
    May 2014
    Virginia Beach, VA
    56
    Will do..I appreciate it!
