Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: first time test with TF-100
    careingemt's Avatar
    Sep 2013
    PA
    143
    This is my first test with my new TF-100 kit. I must say I am impressed how it works it gives you an exact # no guessing
    here are my results providing I counted the drops and did not miss one
    T.C. = 6.5
    F.C. = 6
    C.C. = 0.5
    P.H. = 7.2 - 7.4
    T.A. = 90
    C.H. = 225
    CYA = 40
    Note : cya was added 5 days ago so im not sure if this reading is true. (tfp says it may take one week for cya to show up)
    I would say ph is not swinging around.... last week water tested at pool store P.H. was 7.8
    AG 18 feet accross 52" high pool wall 7000 gallons .... pool math = 7600
    Hayward extreme cartridge filter 100sq feet
    pool is heated by propane Hayward heater
    pool installed aug 12 2013
    Butterfly's Avatar
    South Carolina
    10,045
    Re: first time test with TF-100
    Looking good
    You're done SLAMing when:
    careingemt's Avatar
    Sep 2013
    PA
    143
    I was hoping so. thanks for your input
    so as of right now add nothing to pool right ?
    Jan 2013
    Houston, TX
    1,079
    spot on. enjoy it!
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    careingemt's Avatar
    Sep 2013
    PA
    143
    quick question,
    if c.c. stays at or below 0.5 no need to slam right ?
    add a stick of chlorine when F.C. goes under ?
    when to test again ?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by careingemt View Post
    quick question,
    Treat .5 or less CC as zero. So no need to SLAM.
    Your CYA is already at leat 40. Why would you want to use chlorine sticks? They just drive CYA up and pH down.
    Test FC and pH every day. The others less frequently.
    careingemt's Avatar
    Sep 2013
    PA
    143
    I guess I don't want to create a problem with son he has allergies I know he was fine last year. Scared I guess ... he had heart surgery @ 3 mths old been through alot
    careingemt's Avatar
    Sep 2013
    PA
    143
    Maybe I will consider liquid chlorine
    Feb 2014
    Madison, WI
    8
    I guess I don't want to create a problem with son he has allergies I know he was fine last year. Scared I guess ... he had heart surgery @ 3 mths old been through a lot
    If you are concerned about your son's immune system, keeping an adequate FC level is key. Using liquid chlorine to maintain FC has the added benefit of not affecting your pool's chemistry in other ways such as lowering the pH or increasing the CYA, which will cause problems down the road by requiring higher levels of FC to keep the pool adequately sanitized.
    Test kit: TF-100
    Pool: 33K gal 20x40' IG vinyl w/ diving board, waterslide, fiberglass steps. PacFab PF50 stainless steel sand filter. Hayward H250 heater. Polaris 380 with 3/4hp Pentair LA01N booster pump
    Indoor Spa: 400gal...still gathering info about it
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Definitely a good idea. After you understand the side effects (from other ingredients) of the other chlorine options you'll find yourself reluctantly concluding that "liquid chlorine" (chlorinating liquid) is the best choice.
    You'll probably also find yourself thinking "if only they made <solid chlorine product> without <ingredient, CH or CYA> my life would be so much easier"
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I'll toss in two points. Medical related.
    (cardiac) I can say if(per his MD) it is safe for your son to swim in any pool, a pool chlorinated with liquid chlorine aka bleach is perfectly safe.
    (allergies)There are actually less ingredients in Liquid chlorine than in the Chlorine sticks. So knowing this you're at less risk for an allergic reaction with liquid chlorine.
    I applaud your care and caution, these things seem less and less common.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Smykowski's Avatar
    Sep 2011
    3,065
    If you continue to use our methods, it is a near certainty that your pool will be far cleaner and safer than any hotel/waterpark/public pool you've ever been in.
    careingemt's Avatar
    Sep 2013
    PA
    143
    New test results
    Please do not start a new thread for every set of test results. Keeping it all together keeps your story together. Thanks, jblizzle
    Opinions please
    PH. 7.2
    fc. 4
    cc. .5
    Tc 4.5
    CH. 225
    ta. 80
    cya. 23 - 28
    Not sure if cya is accurate
    careingemt's Avatar
    Sep 2013
    PA
    143
    Sorry .... won't do it again
    38,463
    First there is no way the CYA should have dropped from 40 to under 30 unless you replaced a lot of water. Are you doing it in bright indirect light with the tube at your waist?
    Everything else is fine.
    careingemt's Avatar
    Sep 2013
    PA
    143
    Honestly ..... I don't know if 40 was right. ...... guess I need to practice
    careingemt's Avatar
    Sep 2013
    PA
    143
    Tube at waist .... all tests done in garage under florescent lights and 2. 40 watt bulbs tests done after I put son to bed at 9 pm
    38,463
    The CYA test should really be outside with the sun providing the indirect light.
    careingemt's Avatar
    Sep 2013
    PA
    143
    Well then cya is totally inaccurate
  20. Back To Top    #20
    careingemt's Avatar
    Sep 2013
    PA
    143
    TESTED WITH TFT 100
    PH - 7.2
    FC. - 9
    CC. - .5
    TC. - 9.5
    CH - 175
    TA. - 80
    CYA
    TESTED. AT. POOL STORE
    DROP TEST
    CYA. - 40
