Results 1 to 8 of 8
Thread: How do I plumb my Stenner pump into my soft pvc return hose?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    This is the part that I haven't really thought of per my build... I am using soft pvc UV stabilised hose for my pool hoses this year, they have an excellent guarantee and don't cost much more than regular pool hose, so my question is, what parts will I need, to add my Stenner pump to my return hose for chlorine injection?
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    May 2013
    North East Ohio
    959
    Re: How do I plumb my Stenner pump into my soft pvc return hose?
    Do you have a "plug" in your pump that you can inject into ? I've seen it done this way quite a few times.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Thanks Toofast, I had thought of that, but then I thought, I use 12.5% bleach and I don't want to put it undiluted into my new pump......
    May 2013
    North East Ohio
    959
    remember your injecting into a fast movin flow of water... I don't think 12.5 percent bleach we hanging out too long to do any damage
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Quote Originally Posted by toofast View Post
    Sent from my DROID RAZR HD using Tapatalk
    Cool, it would dilute pretty quickly in fast flowing water... Thank you again for the advice, but I still want to know how to plumb it through the hose....
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Lacy, You will need to some tubing and a fitting to connect the tubing to the flex hose. I believe there are injection fittings made for flexible pipe such as yours. Barbed fittings they are called. There are also ones for hard pvc that are threaded and require making threads in teh hard pvc. Link below to a couple of them.
    Im not an expert, but did some googling about it, so take it for what its worth. Maybe somneone with experience with these things will come along and help out more than I prolly can. (see the quote in my sig about experience. No truer words ever spoken).
    A couple of thoughts to consider.... If the barbed fittings wont work or its not a good idea to inject into the flex pipe, could you perhaps put a hard PVC coupling somewhere in the lengh of pipe and put a threaded one in the hard pcv? Or is there enough space in the connector fitting of teh flex pipe to put one?
    https://www.yourpoolhq.com/stenner-i...FWYV7Aod6ScAgw
    http://www.longerpump.com/product/product172.html
    Divin Dave,
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yes Dave, that's exactly what I was looking for... I don't have the pump yet, so I don't know if its got a plug. So if it hasn't, this is exactly what I'll have to do.... Thank you very much... I have added both pages to my favourites for reference... I'll see if I can get something exactly the same here in Oz... The great thing about pvc flexi hose, is you can drill into it with no dramas....
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Bumping so I can find it again....
