Thread: 2 inch pipe on an Intex Pool
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I was wondering would there be a problem if I used 2 inch hose to plumb my intex pool. The usual size is the 1 1/2 inch, but the suction and returns I just installed, are all 2 inches, so instead of reducing everything down to 1 1/2, is this plausible/safe? My pump and cartridge come with both 2 inch and 1 1/2 inch connectors, but I'm thinking more flow this way? And less stuffing around with reducers and such....
    Thanks Laceygirl...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Casey's Avatar
    SW PA
    10,457
    Re: 2 inch pipe on an Intex Pool
    There should be no problems... that I foresee in going with the 2".
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Yes 2" can be used on your pool, quite well. Suction side will work a little better with the larger pipe, less suction head loss.
    On the return side, I don't think it will matter much which side you use, with short runs. If you are planning on long runs or needing a lot of bends in the pipes, 2" would be better.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Cool thanks guys.... I have one long run from the skimmer.... Its about 10m, but relative to what size most pools are, its not very long... That makes me feel better...
    The trade off for plumbing ease however, is 2 inch hose is a little more expensive than 1 1/2' and so are ball valves, but it means I don't have to do any complicated plumbing.... My pool has two suction sides, and one return as per Aussie regulations..., I plan to add the skimmer, turn one of the suctions into another return, so I will have two suctions and two returns... Nothing too difficult, so all I will need are 4 x 2' ball valves, 3 x 90 degree 2' pvc elbows, and about 20 metres of 50mm pvc hose... And about 12 x 2' stainless steel hose clamps.... Too easy....
    And to bother you good people again.... If someone could tell me the plumbing I will need, in order to add my 3/8' peristaltic pump hose directly into my soft pvc hose return, that would be awesome... I am not sure what parts I need... Any advice is appreciated...
