Results 1 to 10 of 10
Thread: UV Pool
    Apr 2012
    Lynchburg, VA
    90
    UV Pool
    Getting ready to work on my first UV pool next week.
    Any suggestions from the board?
    TIA
    PF
    38,301
    Re: UV Pool
    Would you care to elaborate?
    Casey's Avatar
    SW PA
    10,448
    Re: UV Pool
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: UV Pool
    Is this an indoor pool that is using UV to help control chloramines? If it's an outdoor residential pool, there should be no need for UV since the UV in sunlight provides a lot more and when chlorine breaks down in sunlight it produces hydroxyl radicals that are powerful oxidizers.
    Apr 2014
    Southern California
    45
    Re: UV Pool
    Is the purpose to not have the need for chlorine??
    ~22,000 gallon inground plaster pool, 1 skimmer, 3 return jets
    Irregular pool sized approximately 19' x 40' 9' deep, Color Splash 3G pool light
    Pentair Clean & Clear Plus cartridge filter (part# 160301)
    1 HP Pentair Pump Model WFE-24 single speed
    Light Blue Pool Cover BBB Method
    Apr 2012
    Lynchburg, VA
    90
    Re: UV Pool
    A client of mine has just purchased a house, she was told by the previous owners it is a UV light pool. I am guessing it has a UV light built into the plumbing to kill organisms. Just looking for some advice from the board for opening and care.
    PF
    38,301
    Re: UV Pool
    best advice is to just pretend the uv is not there and open and maintain normally.
    Re: UV Pool
    UV systems has little to no positive effect on outdoor pools. For indoor pools they can be very handy at keeping CC levels under control (CC is far more of an issue with indoor pools). In both cases the UV system may or may not have the effect of slowly but constantly breaking down some of the chlorine. How rapidly it breaks down chlorine depends on the exact spectrum and intensity of the UV source, but it is generally a small effect.
    Apr 2012
    Lynchburg, VA
    90
    Re: UV Pool
    Nothing quite like the EXPENSIVE ease of mind!
    Thanks for the input.
    PF
    Quote Originally Posted by JasonLion View Post
    Why are CC more of an issue with indoor pools?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: UV Pool
    In general, CCs can be broken down by either more FC, or by UV radiation (sunlight). The reaction is much faster in sunlight, so in indoor pools, CCs can build up a lot more than in outdoor pools. UV systems can help in those cases.
