Results 1 to 11 of 11
Thread: Liner Sagging
    Liner Sagging
    Hopefully the installer will come and fix.
    2003 Marquis Euphoria - 400gal
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Liner Sagging
    The same thing is happening to my friends pool, but their's is older, at least 10 years. Is the fix simple? Can it be done on older pools? What causes it? They are thinking of selling, so they don't want to spend to much on the pool at this point.
    Re: Liner Sagging
    Not sure what caused it.. I already emailed the installer. I tried tucking it back in to no avail. We will see what he says.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Liner Sagging
    Wow, jj, your brand new liner
    Hopefully your installer will be back for a quick fix!
    You're done SLAMing when:
    Re: Liner Sagging
    Yea, it sucks. The installer is a great guy though. I am sure he will make it right.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Liner Sagging
    Y'all might want to take a look here for some tips on getting a liner back in track
    Luv& Luk
    -Ted
    Re: Liner Sagging
    Thanks Waste.. I could probably fix it myself if I put a bit more effort into it. But I paid good money and the liner is new. So, I feel the installer should correct.
    Mar 2007
    4,160
    Re: Liner Sagging
    Quote Originally Posted by jjdurrant
    You are correct that the fix is on him! However I thought giving my little nugget on liner tucks a bump might help a few people with similar problems. It is sometimes hard to get them (the PB) to come out in a timely manner especially for a liner tuck and if you could do it yourself with minimal effort, it'd be 1 less thing to worry about 8)
    Enjoy the pool! Hope the dudes come out soon to pop your liner back in!
    Luv& Luk
    -Ted
    Re: Liner Sagging
    PB already replied to my email and will be out tomorrow to rectify. I am curious though, is this common, or simply laziness on the PB's part?
    Mar 2007
    4,160
    Re: Liner Sagging
    I can't see that you would be calling the PB lazy when he's already responded to your e-mail and says he'll send someone out tomorrow to fix it ... Oh, I get it, the bead coming out
    It happens fairly frequently and for a few different reasons.
    #1 is that the liner wasn't fully tucked in to begin with If you go out and look at the bead where it's popped out, you should notice a barb on the backside of the bead. It's possible to install a liner bead that looks like it's all the way in place (the barb locked in) but needs another ~ 1/ 100" to be all the way in and fully catch. I can feel when it catches but someone who is new to installing liners (or doesn't have 20 years experience) might not - no biggie it's easy enough to fix, it'd be better if it didn't need to be fixed, but no harm is coming to the pool nor liner by having it slide out a little for a couple of days.
    #2 the track that the bead attaches to is either warped or ants have built their colony in the track and bumped out the bead. With a warp, usually found in the corners where they have too bend the coping, a little liner lock solves the problem. Ant colonies need to be cleared out before the track will accept the bead again.
    #3 the liner floats due to water build up under the liner and the bead pops out - liner lock will help prevent this, but you've gotta take care of the source of the floating liner.
    I hope this answers the question, if not - just let me know and I'll try it again
    Luv& Luk
    -Ted
    Re: Liner Sagging
    PB just stopped out... liner is good as new again. Really nice guy. He was amazed by my water.. he asked who was doing the maint. He was even more floored when I said me.. Of course, he had to ask what I was doing.. I should Clorox and Trichlor sticks and I think he almost had a heart attack. He was cool, but of course skeptical. I told him to checkout TFP! I even showed him the test kit which he seemed interested in purchasing!
