12000 Gal in ground pebble tech pool.
FC 24 PPM
TC 24 PPM
CH 250
TA 170
CYA 80
PH 7.5
Salt 3000 PPM - By titration
using strips it shows 3.8 which seems to indicate less than 1000 PPM. My SWG indicates 3900, and test from pool store last week showed 3000 also, so I tend to trust the titration test. Not sure what is going on with the salt test strips.
Turned the SWG down from 50% to 25% to see if FC starts to drop. Guess I could turn it off for a few days.
From the SWG water balance info on this site I see that my TA is high.
What should I do if anything to the pool? Which measurements are most likely to be off for a newbee?
Norm
Sent from my iPad using Tapatalk
FC 24 PPM
TC 24 PPM
CH 250
TA 170
CYA 80
PH 7.5
Norm
