Thread: Heavy Rain
    Mar 2014
    Mesquite, Texas
    29
    Heavy Rain
    Thank the good Lord for 3.88 " of rain in Mesquite, Texas!! In anticipation, I bumped the chlorine up to 8 ppm last night. I carry a CYA of 40 and target 5 PPM on a daily basis. We had to drain four inches this evening because the water was up to the coping -- PH is 7.5; FC is 5 PPM, CC is 0.
    Should I leave chlorine level where it is or jack it up to 8 PPM due to the heavy rain. We're back to sun at least until maybe Monday.
    Thanks for all your help!
    14K IG Aggregate Mini Pebble, 1 HP Hayward Single Speed Pump 120 GPM, 175 Sqft Cartridge Filter
    In-Line Chlorinator, 360 Polaris Black Max, Sheer Descent Water Feature. TF-100 Test Kit
    Build Date 2/1994; Remodel Date 4/2014; Original Owner, North Texas
    30,401
    Re: Heavy Rain
    Rain has far less influence on your pool than most folks think. Keep your target FC at 5 ppm.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: Heavy Rain
    But check your PH--heavy rain drives mine up with all the aeration. But yeah-we'll take the rain!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Heavy Rain
    With a heavy rain like you received, it is entirely possible that lots of dirt/debris was washed out of the atmosphere and off of the patio into the pool. That's entirely normal after a downpour like that, especially after a prolonged dry period. Consider giving your pump/filter as well as your Polaris a bit more run time to clear that up. As others have stated, keep FC at your current target of 5 ppm.
