Results 1 to 8 of 8
Thread: Gunite Shot--Thoughts on hosing down with water each day?
    Feb 2014
    Jersey side of Philadelphia
    93
    The gunite crew shot the gunite today. The lead member suggested that I water the pool down twice per day for the next week or so to prevent cracks. My PB indicated that it would be unnecessary since the temperature is fairly cool (50s at night and 68 to 80 during the day) and not up into the hot summer months of July. I mentioned what the concrete crew said and he indicated that I could do that but it is not necessarily necessary.
    Does anyone have any thoughts on this matter. I am thinking of just airing on the said of caution and hosing it down anyway?
    38,548
    Re: Gunite Shot--Thoughts on hosing down with water each day?
    Why not do it? There is no downside.
    Gunite cures just a little better if it is kept slightly moist.
    Feb 2014
    Houston
    35
    Yes, we were instructed to water ours once a day for 7 days unless it rained.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Water it down, it gives you a great reason to go stare at your creation! Good luck and post some pics!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Nov 2013
    Central Texas
    113
    get enough soaker hoses and put it around the edge of the pool. Turn on water and boom done. No hand watering or using a sprinkler in bottom of the pool
    28k gal/raised spa, IG quartzscape, WhistperFlo 2 speed B2984T,DEV60 filter,Lxi400 NG heater, Polaris 280 cleaner, DIY Chlorine injection, Build completion 7/2013
    Casey's Avatar
    SW PA
    10,461
    So have you been watering the pool or not?
    Jul 2009
    Gonzales, La
    220
    I bought a automatic timer, used a hose splitter and used two sprinklers to water the shell twice a day. Around noon and 7pm. Then pumped the water out the bottom with a small electric submersible pump.
    Todd
