Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 102
Thread: Newbie - need some help
    May 2014
    San Jose, CA
    153
    Hi All,
    I am new, but i read a lot here and getting smarter by the minute. Thanks you!
    I do have a question about how to level my yard.
    I bought an Intex 18X9X52, i am wondering if i can level the ground by putting cement/pavement blocks on top of it?
    the ground is already close to being leveled, I need to remove the grass {i assume i'll do it with a sod cutter}, i read people adding sand on top, i don't want to go that road and i am thinking of blocks.
    What do you think?
    Casey's Avatar
    SW PA
    10,444
    Re: Newbie - need some help
    I'm thinking you still need to lay a level down and or a laser/water level before you assume the ground is level. It may look it but 9 chances out of 10, it is not level and you'll have to remove the high side. Using pavers as a base is not such a great idea. The liner is going to sink into the creases and could tear from the blocks. You really need a sand and or soft base to protect the liner. A lot of people have used foam insulation boards from Lowes and or Home Depot.
    Welcome to TFP.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I have the exact same pool.... I'll be tuning in to your build... Pulling up a chair...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Welcome to TFP!
    You are going to have to use either sand or extruded foam insulation board under your pool.
    If your yard looks level, it probably isn't. A 4' level with a straight 10' 2x4 will show you this. Once you have seen how much your yard slopes, you can start at the lowest spot and level to that. Please don't make the mistake of thinking you can fill in the low with soil from the high, it won't work. Within a weeks time of the pool sitting on it, your fill area will have slumped, taking your pool out of level, and possibly causing it to collapse.
    May 2014
    San Jose, CA
    153
    Ok here we go.
    As posted so many times on this site i got a sot cutter and i am starting to work...
    How do i attach pictures?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    May 2014
    San Jose, CA
    153
    Thanks
    Here we go
    May 2014
    San Jose, CA
    153
    Part 1 is done
    Most of the area is leveled except for one part which is low ~2inch
    What do i do? do i need to lower everything because of that?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Yes, that would be the way to go. As stated in the other reply, using fill will only cause problems. I made that mistake the first time I set up our pool. Pain in the back, yes, but worth it with a pool that stays where you want it.
    Casey's Avatar
    SW PA
    10,444
    Looking good! If you get a minute after playing in the dirt tonight, update your profile with your location and your signature with your new pool info... and then read pool school!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Quote Originally Posted by Yaniv View Post
    Part 1 is done
    Sadly, yes. Unless you have access to a power tamper and some base rock.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    The size of the footprint you will need, and this is from outside leg to outside leg, and end leg to end leg.... 6.05cm x 3.30cm so 238 inches x 130 inches....
    Casey's Avatar
    SW PA
    10,444
    As Richard posted... Yes, you need to go off that low point and remove dirt down to it. You just can't build up a pool and expect it to hold under thousands of lbs of pressure (weight). Good Luck! The foundation is the most crucial and toughest job!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I've decided to go with railway sleepers underneath the same pool.... They're 200mm across and 75mm thick..... This pool can hold 17200 litres, therefore it will weight 17 tonnes.....
    30,420
    You can fill that area if you do it correctly. The fill material can not be the dirt you scraped off and it can not be sand which will wash away.
    Most quarries make a product called "screening" (or something like that) it is essentially rock dust with small rocks in it not bigger than 1/4 inch. That is easily compacted, will not compact further and, if you do it carefully, will not "wash out" underneath your pool.
    May 2014
    San Jose, CA
    153
    I did the best i can do with leveling the ground i think it is OK now i am adding the sand
    and I also got the styrofoam (pink) that you recommend here
    Next step is GFCI outlet
    Our Build 2016 14.5' x 26' IG Pebble, 14.5K Gal. 3.5' - 6.5' deep, 5 returns, 2 Skimmers, Hayward VS pump, Hayward 525 Cartridge Filter, Hayward E-Command 4, Heliocol Solar, Hayward LED Light, Paramount Ultraviolet, Polaris 280, AquaRite Pro, T-CELL-15, Sense and Dispense (HL-CHEM), Ph Dispense System (AQL-CHEM3) , Taylor K-2006 with SpeedStir
    30,420
    Place some kind of barrier around the bottom edge of your pool so the sand cannot wash out.
    Your surrounding land is flat enough that you are likely ok but sand is a poor choice for most people as it so readily erodes out from underneath the pool if there is much slope at all.
    May 2014
    San Jose, CA
    153
    GFCI outlet is ready, also the place for the heater and pump is done.
    Next step is to hard wire the pool's plumbing. (And paint the wall )
    May 2014
    San Jose, CA
    153
    Ohhh ok, Thanks for that
  20. Back To Top    #20
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Its coming along... Nice job....
