Results 1 to 12 of 12
Thread: Bubbler Trouble
    Bubbler Trouble
    Hello. Our pool was completed last summer and the bubblers have not worked properly (well, continuously properly) since day one. Both of them won't bubble evenly at the same time. If I straighten out the crazy one, they both work for about a minute then normally the opposite one goes haywire - sometimes they'll shoot like 10' in the air! Makes me nuts. Have told the PB and he's attempted to fix numerous times and they work until he leaves. Then they go crazy again. I'm adding a shot both of normal and and not-so-much normal. Any advice would be great appreciated!
    Well, guess I can't add shots from my phone.
    SunStone Blue Mist plaster; 20,000 gal; 39.5' x 16' (22' at in-pool bar seating), 118' perimeter, 626 sf surface area; 3'6" x 6'6" depth; trichlor auto-dispenser; 2 hp Jandy Stealth Filter Pump; 160 gpm Jandy water feature pump; 460 Sq. Ft. Jandy Cartridge Filter; Jandy RSPS 4 with PDA remote; In Line Chlorinator; A&A Infloor Cleaner; 2 Jandy watercolors LED lights; Ozone Sanitation
    38,354
    Re: Bubbler Trouble
    How To Post Pictures
    You can use Tapatalk to host if you use it.
    Add pictures of the plumbing as well.
    Re: Bubbler Trouble
    As you can see, even when the bubblers are normal, they aren't very even in bubbler height. The 3rd pic is the only one I have on my ipad as far as equipment. If that doesn't help, I'll take a better one tomorrow when it's daylight.
    Re: Bubbler Trouble
    Has anyone ever encountered problems with their bubblers like this?
    38,354
    Re: Bubbler Trouble
    Are they plumbed separately? Are there valves to control each independently?
    You should certainly be able to turn them down and ideally be able to equalize them.
    Re: Bubbler Trouble
    I have the in floor cleaner and when it is on the bubblers are low, but they go crazy when the cleaner is off - so that leads me to believe they aren't plumbed separately. When I hit 'pool mode' on the jandy remote, they come on.
    38,354
    Re: Bubbler Trouble
    Well do you know what all your valves are for? Label them and post more pictures.
    Of course they are going to get higher if you turn off the floor and force more water through them.
    Re: Bubbler Trouble
    Ugh I don't know - I know I should. I just know the PB hasn't been able to fix it. My hubby and I don't know **** except what we learn from this site. We leave the cleaning/chemicals to the weekly pool dude. I was just hoping this is a common, easy-fix problem that others have dealt with. Doesn't appear to be the case.
    38,354
    Re: Bubbler Trouble
    It is easy, you should just have to adjust the valves. But no way for us to know how it is plumbed.
    Re: Bubbler Trouble
    Thanks jblizzle. You'd think my PB would know to do that.
    38,354
    Re: Bubbler Trouble
    Well maybe they did not plumb in valves correctly and thus not able to make the corrections required.
    Re: Bubbler Trouble
    That's what worries me!
