Results 1 to 18 of 18
Thread: So it, uh, rained a little bit in Dallas this afternoon.
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Sheesh.
    (Note: the water looks like **** because of the rain. It's been *perfect* since we bought the house in October and I started in on the TFP method )
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    Jan 2013
    Houston, TX
    1,079
    Re: So it, uh, rained a little bit in Dallas this afternoon.
    Wow. Can you send some to Houston?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Lucky b!?%&* I could sure use a couple feet of fresh water.
    I am thankful for all the rain up here in Frisco as I am doing a first fill. Any relief to my water bill would be great since I have been filling for almost 24 hours and still have a ways to go.
    In ground, 15x27, 80 feet perimeter, 3'6 to 5 feet deep, 13,000 gallons, 2 skimmers, 6 returns, Jandy VSP, Jandy DE 60, Jandy LXI, Nature 2 Ozone, 2 pool LED lights, 1 Spa LED light pebble tech aqua blue. Frisco,
    Texas
    In Ground 15X27 80 ft perimeter; 3'6 to 5' depth; 9600 gallons; 2 skimmers; 6 returns; Jandy VSP; 2 pool LED lights; 1 spa pool light; pebble tech aqua blue, North Texas build complete April 2014
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Quote Originally Posted by karmabiker View Post
    I'll send you some humidity...it can keeps yours company
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Went out and grabbed a quickie water test: FC down to 2. Didn't bother with CC. Fed the pool a jug of 8.25 (3 ppm) and set the pump to turn over the water overnight.
    We'll see what she looks like in the morning.
    Jan 2013
    Houston, TX
    1,079
    Humidity received. Currently 100% and I can't buy a rain cloud.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    We lucked out with steady, beneficial rain and avoided the severe weather that hit parts of the Metroplex.
    Quote Originally Posted by freqz
    Having spent time in both cities, I can relate to how true this is!
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    5" over just a couple of hours here...it was pretty intense. Tornado sirens went off about the time the Mrs. was picking up the boys from school.
    FC 4.5. CC < 0.5. Ph 7.5. CYA 40.
    Water is still pretty murky but improving this morning.
    I'll probably go ahead and start the SLAM this evening.
    edge's Avatar
    Mar 2014
    Douglas, GA
    143
    WOW.
    16'X32'X8' Vinyl Pond with Diving Board (Neck Breaker), 1.5 hp FOXX WhisperFlo(Not so quite anymore), Massive Lawn Egg (aka: Sand Filter), Coolcrete Pool deck (Burns feet to a crisp), Large wooden Multi level deck (Splinter City) with fire pit in center (Insurance company's nightmare.)
    737mech's Avatar
    Jun 2013
    Corinth,TX
    148
    I was trying to leave work yesterday when it was raining cats and dogs. I haven't seen that much rain in such a short period of time in awhile. Streets were flooded to the point you couldn't see the curbs.
    Sorry for you pool problems.....it will get better.
    Finally completed March 2014
    IG 27,300 gal 35'x16' 3.5'/5.5'/8' diving pool, Pentair Intellichlor IC40, De FNS 60, 3HP Intelliflo VF pump, Easy Touch 4, Kreapy Krauly Platnium, 3/4 Hp booster pump, raised stone wall w/ 2 stone scuppers, Stonescapes aqua blue mini pebble plaster
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    The pool looked better this afternoon-- I could see the main drain, anyway.
    No CCs. Everything else was normal except for the green tint, haze, and dirt all over the bottom.
    SLAM has begun including a good brushing. Hope we can clear this up pretty quick.
    Casey's Avatar
    SW PA
    10,423
    I'll say it rained! Ghesh!!!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I'm sure it lowered your CH!
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Quote Originally Posted by BoDarville View Post
    Lol. I'm sure it did!
    Water is clear again but I lost 5ppm FC in 4 hours showing 1 CC. MOAR BLEACH! Hopefully we pass the OCLT tonight.
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    OLCT passed. Water crystal clear. That was fast!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job freqz 👍
    Jeff
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Cleaned the filter this afternoon. Back to normal
    (Yes, I need to finish skimming...thanks for noticing)
