Thread: cleaning up after sudden algae bloom
    May 2014
    hope mills, nc
    18
    Pool clar allwinter...a little dirty but blue.maitained t/o winter with bleach. One day almost 2 weeks ago clear in am and GREEN by 8pm. Shocked with 6 of the8.25%concentratrd bleach containers (larger than 1 gal) cleared algae now cloudy. Been running pump continuously and back washing with 2-3psi increases and vacuuming. I have a taylor dpd test kit here are my readings from this am
    TC 3.3
    FC 0.0
    Ph7.2
    TA140
    Ch 125
    CyA15
    Phosphates 500
    Help please and thank you
    Above ground 24ft round 54 in deep 1hp 2speed Hayward power flo matrix pump& sand filter.
    38,300
    Re: cleaning up after sudden algae bloom
    Welcome to TFP!!
    What Taylor kit are you using? A TC reading of 3.3 is not possible with the kits we recommend. CYA of 15 is below the minimum of the test. And phosphates are not tested for (because they do not matter).
    You need to follow the SLAM Process until you pass the 3 criteria to stop.
    Casey's Avatar
    SW PA
    10,446
    Keep SLAM'ing and read Pool School. You just can't read it enough!
    May 2014
    hope mills, nc
    18
    I own the taylor one recommended here but to clarify those are reading from my pool store test.
