Thread: AA Treatment effectiveness: Algae Present
    Apr 2013
    Suburbs of Chicago
    76
    It seems I waited to long to open the pool (just finished up new electric) and now have algae. I still would like to run the AA treatment before I open the pool to clear some staining. Is it OK to start the AA treatment while algae is present? Is it less effective then if I were to slam the pool, then let FC drop to 0 with an addition of Poly then do the treatment? Or could I just do the AA treatment and then after I see my results then continue to slam the pool.
    Fiberglass/Concrete IG
    Pool Size: 16500 gallons
    Filter: Hayward S244T Pro Series Top-Mount Sand Filter
    Pump: Hayward 1 HP Super Pump
    38,299
    Re: AA Treatment effectiveness: Algae Present
    The problem with doing as you suggest is that high levels of FC can redeposit the metal stains. So, you should SLAM and pass the 3 criteria to stop. Then add poly quat algaecide, let the FC drop, do the AA treatment, and then slowly increase the FC level and keep sequestrant in the pool.
    Casey's Avatar
    SW PA
    10,446
    Definitely SLAM first so when you do the AA you can watch the magic happen! I hear it's instant!
    Apr 2013
    Suburbs of Chicago
    76
    Great thanks for the information, just about finished with the SLAM process, but I did have an another question about the AA treatment. So after I am all said an done with the treatment and no longer see the stains, will I have to continue introducing sequestrating agent for the life of the pool to hold the metal from reapplying?
    Yes, though not necessarily the life of the pool. If you replace water with metal free water you can stop using sequestrant.
    Apr 2013
    Suburbs of Chicago
    76
    OK cool, so I am guessing between back washing and each season when I drain some water I could potentially rid the pool completely of the metals. Good stuff thanks.
