Results 1 to 7 of 7
Thread: Trying to help a friend open their pool
    Jul 2012
    Seymour, In
    49
    17,000 gallon IG vinyl
    FC = 0
    CC = 0( from 0 FC I guess? After testing FC, adding the 5 drops of R-0003, it did not change the color)
    PH = 8.2
    TA = 130
    CYA = 20
    Pool has green tint, can't see bottom. First steps? Slam process to get FC up and try to clear up the green tint? or do we address something else first?
    Thanks!
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Trying to help a friend open their pool
    Lower PH first---then have at it.
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    I agree with Woodyp. PH over 8.0 is very high and needs to be addressed.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    Jul 2012
    Seymour, In
    49
    That is what I was just double checkiing on in the pool school. Drop PH and start and start slamming.
    Thanks!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by deeanron View Post
    Thanks!
    Right, and we would also like to see some pics along the way
    You're done SLAMing when:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree drop pH, start slamming, but you may want to double check that CYA as you go and boost it up a bit, but not too much until you finish the SLAM
    Casey's Avatar
    SW PA
    10,461
    Quote Originally Posted by Butterfly View Post
    Yep yep! Green to clean!!!
