Thread: Newbie - How long to run pump/filter each day?
    May 2014
    Poway, CA
    2
    Hi all, hoping someone might be able to help answer a filter/pump question. I have an 18x52 round above ground pool with a Pentair Optiflo 1HP 60hz pump. We just opened the pool for summer (we're in San Diego) and I'm trying to figure out how long the pump/filter should be running each day. I've seen calculations online but the numbers aren't making sense. Any advice would be appreciated. Thanks in advance...
    38,520
    Re: Newbie - How long to run pump/filter each day?
    Welcome to TFP!!!
    We happen to have an article about that very subject in Pool School. See this:
    http://www.troublefreepool.com/conte...-pump-run-time
    Lots more for you to read and learn about in there as well
    Casey's Avatar
    SW PA
    10,457
    I run mine a few hours a day and mainly to circulate my chlorine.
    Jun 2013
    Newcastle, Oklahoma
    508
    right now just 2 hours in the morning, which is also when I test and add any chemicals. probably starting next week I will set the timer for a 2 hour evening run as well as we are about to start really using the pool.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    May 2014
    Poway, CA
    2
    Welcome to TFP!!!
    Thank you sooo much!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    I think I run three hours a day now. Plus whatever it gets when I'm vacuuming.
