Results 1 to 10 of 10
Thread: Problem between pump and return
    Randall5301's Avatar
    May 2014
    Virginia Beach, VA
    5
    Good day all
    I looked through all 6 pages and didn't see any posts related to this issue so I apologize if there is 1 already on file.
    I bought my house last year and had a pool guy maintain it until I moved in in October. Due to climate I closed it before I could even enjoy it. Everything worked fine and then I closed it using this site and Youtube videos for reference. I back-washed the filter, blew out all pipes, plugged them, and set it to Winterize. Now trying to re-open, balance the water, shock it, ect. but I am having issues with the filter or valve. What follows is everything in the best detail I can think of, so please bear with me. I have the pump on and is full primed, I know this because 1) the sound, 2)the skimmer keeps suction the entire time, keeping the pool surface clean and 3)I can see the water movement through the window. The valve is set on filter, no leaks anywhere, but there is no pressure coming from any of the return jets. If I turn the pump off, wait a few seconds, and then back on, the jets will blow out the air and then water, but for no more than an hour before it loses it again, almost like a clog. I then back-washed the filter for a few minutes, to ensure clog or no clog, rinsed the sand to re-settle it, then filter again. Same thing happens, plenty of suction from skimmer, but loses any return pressure after less than an hour. So I decided to set it to recirculate to by-pass the filter, however water also exits through the waste port. Would this issue with the valve tie in to the problem of losing return pressure after a while of filtering? Or are the 2 problems unrelated? Any advice or comments will be greatly appreciated.
    Thank You!
    -Randall
    p.s. I did not post chemistry because I dumped chems in water before realizing the issue with the water circulation and I don't think the balance has an issue with this?
    1) 34' x 16.5' 20k gallon.
    2) Sand Filter with Hayward SP0714T XL Valve
    3) In Ground Blue Vinyl
    4) A.O. Smith ST1072 3/4 HP Pump
    Casey's Avatar
    SW PA
    10,423
    Re: Problem between pump and return
    Welcome to TFP! What is your water quality like? Clear, cloudy, green and mucked up?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    If it takes an hour for the flow to be reduced it sounds like the filter is doing it's job. As far as water coming out of the waste port, that sounds like a spider gasket issue. Can you post pictures of your water and equipment?
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    38,246
    Welcome to TFP!!!
    The water leaking out of waste while on recirculate is likely a problem with the spider gasket in the multi-port valve.
    The reduced flow I would guess is due to the filter doing its job and capturing debris. What does your pressure gauge show after a backwash and when the flow appears to reduce?
    Finally, when you turn the pump off there should not be any air getting into the system. The pump should stay primed and the filter should stay full of water.
    May 2014
    Virginia Beach, VA
    5
    -Very green! Rained heavy the past week then plenty of sunshine.
    -Unfortunately now I realize the pressure gauge also is not working, the needle doesn't move with filter or back-wash as it is on the wrong side of the pin. I might be better of just getting a whole new valve altogether as I have read it is difficult to change out the spider gaskets?
    -When I turn the pump off, i can hear the water dropping out of the pipes so it does lose its suction. I could understand reduced flow from the return, but all flow from return jets stop altogether.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    Well, there's two things going on... a bad spider gasket (99% probability that's why water leaks out the waste port) and a filter that's doing its job. That green stuff has to go somewhere, and the filter is it.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Changing the gasket is very easy. There are several "How to" YouTube videos.
    May 2014
    Virginia Beach, VA
    5
    The requested photos can be found here:
    https://plus.google.com/u/0/111990065864182410033/posts
    hopefully that works, have been trying to upload 3 to the site since am, but no luck
    38,246
    Apr 2013
    North OKC Area
    300
    Definitely change the gasket before replacing the valve. Getting a new valve without checking the old gasket is like buying a new wheel with a tire already mounted because your old tire had a broken belt.
