Thread: Avoiding a solar cover reel
    I just installed a new 21x38 IG free form pool and I'm loving it. We also have a gas 200k btu heater but only plan to use it in the spring or fall to extend the season due to cost of gas. I see lots of recommendations for getting a solar cover to reduce evaporation and heat loss at night in the summer and to keep the temp nice without using the heater, but it seems that these are a real pain... The reels are unsightly in my opninion and from what I hear, it takes more than one person to move the reel away from the pool if you want to clean up the pool area for a party.
    So, is it possible to just use 2 smaller covers (oval or circular shape) that can be somewhat easily rolled up by hand and set aside when not in use? Is this more of a pain than the reel?
    21,000K IG Vinyl Free Form, 1.5 HP Pump, Sta-Rite filter, 5 jets, 2 drains, SWG, 200K BTU gas heater
    Floater's Avatar
    May 2008
    Southwest OH
    111
    Re: Avoiding a solar cover reel
    You can cut the solar cover into strips (maybe into thirds), which make it a lot easier to either take on or off and store away...for the party
    ~_~ Sherry ~_~
    24' Round AGP, 13,500gal, 1.5hp Hayward
    Cartridge
    TF100 Test Kit BBB Baby!!!
    Solar covers are not as bad as you think.. my wife was able to do it at 7 months pregnant.
    2003 Marquis Euphoria - 400gal
    Butterfly's Avatar
    South Carolina
    10,045
    One of our members, AnnaK, has a guide on cutting/storing your solar cover. You might want to check it out:
    http://www.ellerbach.com/Pool/Solarcover/
    Hope this helps
    You're done SLAMing when:
    mas985's Avatar
    Pleasanton, CA
    11,737
    This is what I am using. It is a roller that rolls up on itself and makes it easier to remove the cover.
    Mark
    We have a similar size pool (18 X 40).
    We cut our cover into 4 10X18 pieces. We fold each in half (5'), then roll it up. We have 4 large garbage bins tucked away in a hidden corner of the yard that we toss them in.
    Makes the whole process pretty simple, and keeps everything clean.
    Jim
