What type of caulk to use
plucky71
117
Michigan
I have to replace the caulk that is around the edge of my pool. It is used to caulk the gap from where the cement pad meets up to the fiberglass pool. The original Caulk appears to be a clear silicone. Does anyone have any suggestions as to what type of caulk I should use after I remove the original caulk which is falling apart.
I have the same type of pool, fiberglass side concrete bottom. To seal the joints between the two materials we use a polyurethane caulk made by sikaflex. It is marine grade for underwater use. Don't remember the specific model.
