Thread: How to cover ladder hole in cement
    plucky71's Avatar
    Apr 2010
    Michigan
    116
    I have an opening, or a socket, in the cement pad next to my pool for the inground ladder is supposed to go. Does anyone have any suggestions for a way to cover up these sockets because I'm not going to be using the ladder.
    Outdoor fiberglass inground 15,000 gallons, Clean & Clear Plus 420ft. sq. filter, 1 h.p. WhisperFlo pump, New water cycler automatic chlorinater(not using), 1996 pool, TF-100 test kit.
    30,421
    Re: How to cover ladder hole in cement
    Ardex makes a product available at HD or Lowe's called "Feather edge". It is essentially concrete. It won't match your existing but it will fill the hole.
    My suggestion would be to fill the hole to within 1/4 inch from the top and then let dry for 24 hours. Then, do a second mix to fill in that last 1/4"......you'll get a better looking job.
    plucky71's Avatar
    Apr 2010
    Michigan
    116
    I'm sorry, I did not clarify. I only want to cover them for this swim season because we are not using the ladder this year. So I only want a "temporary" cover. Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    How big is the hole? How about driving a PVC pipe cap into it? When you want it out, drill a hole and stuff a prybar in and lever it out.
    Jul 2012
    Cary, NC (Raleigh)
    69
    I too would like to know if anybody has done this or purchased something.
    We have 4 ladder holes. They are the plastic variety that are bonded and then anchored down by the concrete pool deck. Just haven't found anything that would look decent to temporarily cover/plug them since they are right by the entrance stairs.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'm with Richard. Measure the holes. Find PVC pipe caps that will fit snuggly in the hole. When you want to remove, drill/pry them out. Very cheap at local hardware store.
    Isolated Spa - 345 Gallons
