Results 1 to 13 of 13
Thread: Premixing CYA
    Apr 2013
    North OKC Area
    300
    Premixing CYA
    Would there be any issues with mixing CYA with water into a 5 gallon bucket so you don't have to wait a long time for it to dissolve in your pool? Just wondering if you can make your own liquid CYA for future use.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    30,432
    Re: Premixing CYA
    Others on the forum have tried it and report back that it doesn't mix well at all and there is little to be gained in pre-mix.
    Re: Premixing CYA
    CYA will never dissolve in a bucket.
    Apr 2013
    North OKC Area
    300
    Re: Premixing CYA
    Thank you both
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: Premixing CYA
    Quote Originally Posted by JasonLion View Post
    I'll attest to that. I tried it, complete waste of time.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Premixing CYA
    Been there done that.
    I wonder if it is a water temperature or saturation related thing.
    Re: Premixing CYA
    Saturation, some minuscule amount does dissolve, and then the water is saturated.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Premixing CYA
    I wold suppose that like so many other solutions, you could supersaturate by using heat, but how high a heat? Not worth trying!
    Re: Premixing CYA
    Heat helps more dissolve, but still not enough to be useful.
    Re: Premixing CYA
    ^^^ This. Been there done that. Waste of time.
    18' x 36' saltwater inground vinyl pool
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Premixing CYA
    The Natural Chemistry® Instant Pool Water Conditioner product is a slurry of sodium cyanurate. That is made from Cyanuric Acid by adding Lye (sodium hydroxide) to it. This isn't as easy as it sounds so I wouldn't recommend trying to do this yourself.
    Re: Premixing CYA
    Isn't Liquid CYA available at the pool store? something in cocentrated form that you would add water to?
    Pool match makes reference to a liquid?
    I hate dealing with the granular.
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Premixing CYA
    Quote Originally Posted by Rockstead View Post
    Yes you can get liquid stabilizer at the pool store or online, but it is a little pricey IMO.
    Jeff
