Thread: Manual vacuum head
    May 2013
    Missouri
    53
    Manual vacuum head
    Does anyone have a preference for a manual vacuum head style or brand? I have an automatic pool cleaner but it always misses spots so I am going to get a manual head to get those areas. I see triangle shaped ones, rectangle shapes, some with wheels, some with brushes, some without. I am leaning towards one that is kind of rectangular shaped with some little brushes on the side but I would like to know opinions and pros or cons of the various shapes. Thanks!
    June 2013 24 x 52 Sharkline Heritage AGP (13,500 gal), 2 speed 1 hp pump, 150 lb filter(?), TF-100 test kit
    My first pool ever, pool school student with lots of questions
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Manual vacuum head
    The wheeled ones are generally not intended for vinyl pools. Make sure whatever you get is for vinyl.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    All I can say is avoid the HTH vacuum head. I bought one recently when mine broke and the only ones at the pool store where for plaster pools. The HtH has a dual size hose connector, so the actual opening is 1 1/4" instead of 1 1/2". Makes a big difference when you are vacuuming a lot of leaves. It clogs up tight very quickly.
    I have thought a triangular head would be nice for getting behind the steps a little more.
    Love TFP? Become a
    TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a triangle shape one. Works pretty good. Only thing about this thing is it has brushes on the bottom of it. If you try and move it too fast, the brushes will stir stuff up on the bottom too much for it to get sucked in. Go slow with this, and it works well.
    Disclaimer: This is the only one i have ever used, so there might be better ones that I wouldn't know about.
    http://www.doheny.com/poolsupplies/D...cuum-Head.html
    Divin Dave,
