Thread: When to add salt
    RenegadeT's Avatar
    Apr 2013
    GSO, NC
    28
    When to add salt
    I'm reading as much as I can here, trying to make this pool care second nature to me. I encountered advice in this thread (http://www.troublefreepool.com/threa...y-test-results) and was surprised by the recommendation to add salt last. I didn't think the salt concentration affected the test results much, and i would've thought to add the salt right away, to make sure the SWG had ample supply to chlorinate, plus I hate when I see the 'low salt warning' flashing on the controller.
    I didn't want to hijack that thread...why add the salt last?
    TF100 kit, 26k Gallon 18x36 Vinyl inground by Blue Haven Pool, TurboCell T-15 SWG, SmartPure ozonator,
    Hayward SmartFilter cartridge with 1.5hp dual spd. Hayward SmartMax Star Pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: When to add salt
    You add the salt last because you want to get everything else balanced first. It's one less variable to play with. Lots of people have to start the season doing a major cleanout. Why add salt only to lose it right away to backwashing?
    RenegadeT's Avatar
    Apr 2013
    GSO, NC
    28
    Back washing...good point, but that doesn't apply to cartridge filter systems. What other measurements does increasing the salt ppm affect? I was under the impression low salt level could be bad for the SWG. Not trying to be argumentative, just trying to get a better understanding of this. Thanks.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Salt won't effect any other levels. The SWG just won't produce chlorine if it's too low.
