Thread: Crystal Crete Refinish, how often?
    Mar 2013
    Cayman Islands
    30
    The owner of the resort wants to know if we need to refinish the surface of the pool. I haven't the faintest idea, so I told her I'd ask here.
    My question is how do you know when it's necessary? Ours looks okay, and still holds water. Some of the grains of sand in the finish come out here and there, but I don't think it's a big problem especially now since we've changed the water and have the chemistry under control.
    Thanks!
    46,000 gallon in ground concrete/crystal crete, filter is Pentair Pack Fab 60 DE, freshwater.
    2hp pump. Flow Rate ? 4 return jets, two of which are closed due to a leak in the plumbing
    Water is replaced/replentished using RO water
    38,246
    Re: Crystal Crete Refinish, how often?
    In general it is mostly aesthetics until you get major cracks and chunks falling off. It could be in very rough shape and it still be a functional pool, but not likely desired in your case for a resort.
    Mar 2013
    Cayman Islands
    30
    Thanks for the response, that's good to know.
