Results 1 to 8 of 8
Thread: Help with my test results
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    Hi guys. I just ran my first test of the year and here are the results:
    FC 0
    CC 0
    Ph 7.2
    CH 100
    TA 90
    CYA <20
    Salt 2600
    I know I need to add CYA to about 70-80 for my salt pool, add salt to get to around 3,000 or so, get some chlorine (added bleach this morning after the test), and get the PH up to about 7.5 or 7.6.
    What do you think about the TA of 90? The documentation with my SWG recommends 60-80 TA. How can I go about lowering this a little?
    What order should I add the ingredients above? Borax and CYA first, then bleach, then salt last?
    Thanks!!!
    18 x 36 vinyl liner IG pool, grecian shape, ~27k gal
    1.5 hp Hayward Super Pump, Hayward DE3620 Filter
    Hayward Aqua Rite Electronic SWG, Dolphin Triton PS robot
    TF-100 test kit with SpeedStir
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Help with my test results
    Here's my .02.....bleach first, CYA second, salt last. Don't worry about TA for now, it's close enough. I wouldn't bother with the borax, as the SWG is going to drive your pH up for you.
    30,431
    +1 what smykowski said.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Just to be sure, the water is circulating? Because it can sort of layer if you got a lot of rain over the winter.
    How does it look? No algae? No cloudiness? You can see the bottom okay?
    If it is circulating, then get some bleach in there and add some CYA to get it to about 70. And if everything settles down nice, add salt and fire off the SWG!
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    The water is very clear after I added the bleach last night. FC is at 3 now. I'll get the CYA going. It's gonna take a lot to get it to 70!
    I will hold off on the Borax and keep monitoring pH.
    thanks, you guys are awesome!
    drestes's Avatar
    Sep 2013
    Rome, GA
    34
    Well, my pump has quit running. It had frozen up a few days ago and i was able to get it running (barely) for the last few days. The LPS says the bearings are shot. I found a replacement (same model) on Amazon for fairly cheap ($350) and have ordered it. I expect it will be early next week before it arrives and I can get it installed.
    My question is this - how can I keep my clear water from becoming a green swamp before my new pump is installed? Is it safe to add a little bleach to it to keep some chlorine in the water, or should I not bother since there isn't any way to circulate it?
    Thanks!
    Richard320's Avatar
    Jan 2010
    19,051
    Keep some bleach in there. You'll have to mix it manually. Take some Motrin beforehand and get to work with the brush. One lap around the pool ought to stir things up enough to keep it mixed. A few jugs now will save dozens later. I wouldn't bother with the CYA until you have good flow again.
    38,463
    Bummer, you missed the perfect opportunity to upgrade your pump situation by getting a smaller 2-speed motor and ultimately saving money on electricity for the life of the motor.
    You should still slowly pour bleach into the pool and then brush the pool down to mix it in.
