Thread: Call the leak detector or the guy with the video monitor on the drain snake?
    May 2014
    Lewisville, TX
    2
    Cool Call the leak detector or the guy with the video monitor on the drain snake?
    Hi
    So, My pool has 3 skimmers with 2 not working at all. One of it has always got a plug in the skimmer by the time we got the house. I am guessing there is a break in the skimmer line. The other skimmer is having a very bad clog or may be broken. My question is I keep reading about leak detection and video montiring of underground plumbing etc with a snake.. So, which of these two should I be having to do to figure out whre the break is in the line? I called American Leak detection but they charge arounf 325 which is kind of high for my budget. I found a company who is willing to do the leak detection on my plumbing lines for 150 or so.. However I want to know for sure I am going the right path.
    PS: We already tried C02 can, Drain King etc but got nothing out of it.
    Please help.
    Thanx
    Aug 2011
    Southern California
    188
    Re: Call the leak detector or the guy with the video monitor on the drain snake?
    Can the video monitor make it through 90 degree fittings? If it can, then I'd take that before a detector. I've had a leak detection company come out and miss three times trying to find a leak under a house slab. The original leak was spraying against a second pipe running near it and made the guy believe it was the one leaking.
    May 2014
    Lewisville, TX
    2
    Iam goin to find out about that. thanks.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    That seems like it would work if the leak is catastrophic, like a busted pipe or badly cracked fitting. Something smaller may not show up on camera.
    Apr 2014
    Ontario, Canada
    49
    Would a leak detector detect a leak in a suction line (skimmer)? There wouldn't be any water leaking (unless under positive pressure), there would only be air leaking into the line.
    I ended up digging and listening for where the leak was.
    (see my post "Before I dig...") I have sort of the same issue, but only one skimmer line.
    18k IG vinyl pool, Jandy CV460 Cartridge filter, Hayward MaxFlo Variable Speed 1.5hp pump (SP2300VSP), Hayward Aqua Rite Salt Generator with 25K Gal Cell, Teledyne Laars Series One heater, Blood, sweat and tears manual cleaner (trying to decide what to get to replace me), no automation.
