Results 1 to 12 of 12
Thread: TX: New user/pool owner here!
    May 2014
    Pflugerville, TX
    148
    Hello Folks,
    I was directed to join your fine forum from some users on Reddit. I recently bought a house with a "saltwater" pool that I'll be wanting to maintain myself. I'm hoping to learn how to clean and care for my pool with little trouble.
    Casey's Avatar
    SW PA
    10,461
    Re: TX: New user/pool owner here!
    You've come to the best pool forum on the net! Welcome to TFP!
    Read Pool School and order a a reliable test kit like the TF100. It's the best one you can use to take charge of your pool and enjoy crystal clear water. We're here to help you but you have to do your home work by reading pool school several times until it's crystal clear.
    Add your pool specs to your signature in settings below the Pool School logo at the top right of every page... let us know what kind of pool and equipment you have.
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by Casey View Post
    Thanks! I don't know much about the system yet. It's got a bunch of Jandy valves and a Jandy PDA-PS4 to run most the stuff. Once I get a list of components I'll add them.
    I did find a few specs in my pool inspection report, is that what you were looking for?
    Casey's Avatar
    SW PA
    10,461
    You can also post pics to get help on identification if you're not sure! We have so many knowledgeable people here.
    May 2014
    Pflugerville, TX
    148
    I added some signature stuff, hope it shows up.
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Mindflux View Post
    Signature looks good, just need approx. pool volume and liner/wall type of the pool. You can calculate approximate volume using PoolMath link at top of page (bottom of PoolMath page).
    Isolated Spa - 345 Gallons
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by JVTrain View Post
    Thanks. I'm trying to find the previous owners build report. If I remember right it's about 13,000 gallons.
    Casey's Avatar
    SW PA
    10,461
    Sig looks good. Thanks for adding your specs!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    This fine forum has also provided a calculator to help us determine what and how much to put in the pool. Here is a link to it. dont worry too much now until you have read pool school and got your recommended test kit.
    The calculator will help calculate the volume. Look at the bottom, fill in the length width and average depth and click the calculate button.
    the name of the calculator is Pool Math. Its on one of the tabs at the top of the forum page.
    http://www.troublefreepool.com/calc.html
    Welcome!
    Divin Dave,
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP! Looks like you have already received some good advice with regard to Pool School, ordering a good test kit, and updating your sig with your pool's information.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Yet another Texan. Welcome!
    Howdy Fellow Texan!
    In Ground 15X27 80 ft perimeter; 3'6 to 5' depth; 9600 gallons; 2 skimmers; 6 returns; Jandy VSP; 2 pool LED lights; 1 spa pool light; pebble tech aqua blue, North Texas build complete April 2014
