Results 1 to 13 of 13
Thread: Prefered liquid chlorine brand
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Is there one folks? Or as long as its 12%+ its good?
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    38,237
    Re: Prefered liquid chlorine brand
    Whatever is cheaper based on using this: http://www.troublefreepool.com/threa...ine-calculator
    Assuming that it was stored reasonably well and not very old. In some areas, the regular 8.25% bleach is a better deal.
    Casey's Avatar
    SW PA
    10,421
    I just buy the GV unscented bleach from WalMart.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Thanks folks. Going to Costco today, will check out what they have there
    Apr 2014
    Southern California
    45
    Try your local pool store they should carry 12.5% with the price
    per chlorine equivalents cheaper than most, plus you lug around and pour less. Just be prepared for the "why liquid you'll raise your TDS"
    ~22,000 gallon inground plaster pool, 1 skimmer, 3 return jets
    Irregular pool sized approximately 19' x 40' 9' deep, Color Splash 3G pool light
    Pentair Clean & Clear Plus cartridge filter (part# 160301)
    1 HP Pentair Pump Model WFE-24 single speed
    Light Blue Pool Cover BBB Method
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I use walmart, target, or local grocery store (farm fresh) store brand. 8.25%
    I just bought my first 4 bottles of 12.5% from Ollies yesterday on a tip from someone on the forum who lives close to me. $2.99 for a gallon of 12.5% is a great deal since that's what I usually pay for 121oz of 8.25%!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by PharmerAnthony View Post
    The first time I got told the "But you'll raise your TDS!" from the pool store I wasn't quite prepared, but I am now.
    Isolated Spa - 345 Gallons
    38,237
    I just got that talking to a few weeks ago ... they had no idea who they were messing with
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I guess I'll just pile on and say, "Whatever works out cheapest." But don't forget the gasoline cost. I won't drive 25 miles to save 10 a gallon.
    It's sort of like table salt. Is Morton's really any different than the store brand?
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    So... What is TDS? ) only my second year with the pool, still kind of noob.
    38,237
    Total dissolved solids ... includes cya, salt, CH, etc
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Ah ok. Thanks. So this isn't necessarily a bad thing then, both my cya and CH are a bit low at the moment.
    30,402
    Well, that can be a bad thing. I think you possibly have misunderstood TDS. TDS is an irrelevant parameter for a pool so can be ignored.
    Both CH and CYA are important parameters, so if they are low, they might need to be adjusted.
    You can find the acceptable ranges for CH and CYA in Pool School......read "The ABC's of Pool Water Chemistry".
    Post your current test results if you need some help with them.
