Thread: Dumb question
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Dumb question
    Just curious...I like to take suction from the pool and return it to the spa so the spill over breaks up the surface tension of the pool. Any thoughts on this? Is it a good thing, bad thing, or just doesn't matter? Thanks in advance!
    Carl
    IG Plaster with raised spill-over Spa, ~26,000 gallons, Built 2001
    Cartridge filter
    Solar heated
    38,475
    Re: Dumb question
    It adds aeration which will drive the pH up more than without the spillover.
    There is nothing "bad" about that though.
    Re: Dumb question
    For the most part this is easy to do and makes little difference. However there are some very minor negatives. First, the extra aeration from the spillover can sometimes cause the PH to go up constantly, and second the water diverted to the spa could potentially (but not likely) cause there to be too little flow to get proper circulation in the pool.
    Of course "breaks up the surface tension of the pool" really doesn't serve any purpose, though it is often nice to look at.
    Generally you want to spillover to run for about one hour a day, to insure the water in the spa gets properly circulated.
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Re: Dumb question
    Thanks. I know that breaking the surface tension didn't do anything and it's main purpose was simply that...it's nice to look at. Appreciate all the help!
    Cartridge filter
    Solar heated
