Results 1 to 12 of 12
Thread: Which suction side cleaner is best for 16 x 32 above ground with deep end?
    Jun 2013
    Newcastle, Oklahoma
    508
    Kreepy Krauly?
    Baracuda Ranger?
    aqua ez vac?
    ive never had one before, and am interested in one. our local pool place has the ranger for 169.00 and aqua ez vac for 179.00, or should I pony up nearly dbl and get a creepy krauly off the net?
    thanks!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    38,316
    Re: Which suction side cleaner is best for 16 x 32 above ground with deep end?
    If I were looking for a suction cleaner, it would the The Pool Cleaner. Second choice would be the MX-8, but more recent reviews do not seem as good so that is falling behind.
    Jun 2013
    Newcastle, Oklahoma
    508
    looking at these things, im still trying to grasp how in the world they work. i get that the suction from the pump powers it, making it move and sucking up debris, but what guides it? what keeps it from just going back and forth over the same area? what guides it around the pool to ensure it gets the whole thing?
    these things look awesome if they work! im tired of vacumming....
    38,316
    Nothing guides them, they are suppose to move around randomly. Now do they hit 100% of the surface, doubtful. You may find they always miss one area or another. Easiest to just brush those areas to a place where the cleaner does go ... or vacuum.
    Jun 2013
    Newcastle, Oklahoma
    508
    so, jblizzle, do these things actually work good? looking through the threads here, everyone seems to be getting the 1000 dollar robots and not these. I dont hardly get any leaves, mainly just some dirt in the bottom. i currently vac once a week for this dirt, but once we start really using pool in a week or so, I will have to vac more often.
    if I toss one of these cheaper suction vacs in, will it get at least 85% or so of the dirt on the pool floor?
    38,316
    Quote Originally Posted by gtnos View Post
    I will go out on a limb and say ... maybe
    Ideally some places that sell these things will let you try them briefly to see if they work for you.
    Jun 2013
    Newcastle, Oklahoma
    508
    thanks jblizzle, I dont think I can justify a grand for one, even with the new pool we are about to start on. I mainly just get a little dirt in the pool, and dont mind vacuuming most of the time. A cheap one that will get up most of the dirt when I dont feel like vacuuming would be nice. If I end up trying one, Ill be sure to check the stores return policy first....
    Casey's Avatar
    SW PA
    10,448
    I want a pool rover jr. He's got a cord that plugs into the outlet and you just drop him in the pool. That's about all I know about him and he goes over wrinkles so I'm thinking he could handle my moon based pool bottom!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I have a iRobot Roomba vacuum cleaner, its the best little appliance I have, if they only made a pool cleaner just like her...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Oct 2013
    Covina, CA (Los Angeles)
    15
    I just recently purchased a Limited Edition "The Pool Cleaner" about two weeks ago and it gets to nearly every surface in my pool and doesn't seem to ever get stuck. It climbs the walls and covers every inch of the floor over time, the only area it has trouble with are the steps and very high up on walls (My pool profile runs from 3.5' to a 9' deep end for diving, it doesn't seem to get more than 6-7' up the walls)
    It does a fantastic job of keeping the pool clean but it does take time to do so. I'm in the process of installing sprinklers and tilling up my back yard so I have a near constant supply of dirt and dust making its way into the pool. Other than the initial clean (I chose to skip manually vacuuming and just let it do its thing) which took ~12 hours, it has kept the pool spotless since... Many of the reviews I have read (which led me to go with The Pool Cleaner) are from people that have had them for 5+ years and the only maintenance seems to be new tires...
    I picked mine up from Amazon in "Used Like New" (Which turned out to be brand new) condition for $250 so if you keep an eye out you might be able to score the same...
    Hopefully this helps!
    15,500 gallon outdoor in-ground 17'x35' quartz pool w/ attached spa; Pentair WhisperFlo WFE-3 pump (3/4hp); Pentair SMBW4060 DE Filter (58sf, 160Gpm), Pentair MasterTemp Heater (400k BTU/hr) Taylor K-2006 test kit
    Jun 2013
    Newcastle, Oklahoma
    508
    thanks Ghost! appreciate the info!
    38,316
    I think Mark (pump expert) has had a Pool Cleaner for something like 9 years ... found it:
    http://www.troublefreepool.com/threa...l=1#post614855
