Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Speedstir Necessary?
    Madison Mike's Avatar
    Apr 2014
    Columbus, WI
    31
    I've been using the Taylor K2106 test kit. After a month of testing, you can just look at the sample and have a good idea of how much bromine is in the water. I will add 6 or 7 drops of the reagent without stirring, and then just swirl by hand to "read" the sample. So my question is, do I or should I be continually swirling the sample when I'm adding drops, or is swirling after adding a bunch result in the same results? I do the same with the TA test. I can tell that I'll be right around 60ppm, so I just add 4 drops first and then swirl.
    Jacuzzi J375 Spa, 415 gallons, Bromine Sanitizer
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: Speedstir Necessary?
    necessary? no. but im sure it makes it nice. ive been thinking about getting one myself.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    30,426
    It is absolutely not necessary....until you get one and wonder why you didn't have it from the beginning.
    I got one a few months before we ever sold them (we really do make an attempt to try the stuff we sell) I was quite skeptical....just my nature.
    After about the first two tests, I was hooked!
    After all that, it is still not necessary but it is a pretty neat little device.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    It seriously makes things easier, and makes the testing more consistent in my head.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    tbone2's Avatar
    Apr 2014
    Hinckley, IL
    14
    I got one when I ordered my test kit. I would compare it to my car lock/unlock remote. Sure using the key doesn't take much longer to unlock, but once you start using a remote you find using the key again to be annoying. Plus with the speedstir, I know everything is getting thoroughly mixed. I'm probably a bit biased right now though. Had to SLAM my pool (foreclosed, unused for 3 year) and the speedstir is extremely handy for the FC test when you're using 40-50 drops at a time.
    18'x35' inground vinyl. ~26k Gallons
    1HP Hayward Super Pump. Jacuzzi 250L sand filter. No additional water features.
    Foreclosure pool, 3 years no use. Yes, that is a bike I got from the bottom.
    TFT-100 Test Kit
    May 2012
    North of Charlotte, NC
    312
    Couldn't imagine NOT having my speedster
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by roadking00 View Post
    This. No one has ever put a post on this forum saying "Man, I wish I would have saved $30 and not bought the speedstir."
    Casey's Avatar
    SW PA
    10,450
    I love the speed stir and use it every time I test the water.
    Apr 2014
    Columbus, WI
    31
    OK, I get it. Not needed.
    I sure am glad I didn't spend the $30 on that useless little gizmo.
    I don't have a speed stir ... but you can bet your bottom dollar that if my pool ever turns green and I have to slam ... I'll be buying one with my order of extra reagents!
    SwimNPlay AG 15x33 oval 48" high 12k gallons - Used pool set up July 2013
    Hayward sand filter, Sta-Rite 3/4 HP pump
    Kleen Machine Robot, TF-100 test kit
    Central NC
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Madison Mike View Post
    You'd be stirring the pot more effectively if you had a Speedstir!
    Isolated Spa - 345 Gallons
    Mar 2014
    Orlando, FL
    35
    Ordered mine yesterday. Can't wait to get it!
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    May 2012
    312
    The amount of time spent driving to the pool store let alone gas in your vehicle that you will not have to do as soon as you have control of your pool by testing your own water pays for the speedster in less then a season of TFP ownership....well worth the $30 bucks for sure.... But not needed.....
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    I get arthritic flair ups in my hands at times and swirling becomes a little clumsy. I find the speed stir very helpful at those times, and just all around faster testing all the time.
    Oct 2013
    Chapin, SC
    1,141
    I don't believe anyone that has one will tell you it's not needed. Besides your question was is it necessary. For my $30 bucks worth, it isn't necessary, but it IS needed!!!
    Last edited by jblizzle; 05-07-2014 at 05:02 PM. Reason: Removed potentially derogatory statement
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My only advice is if you don't want to spend the money to buy one don't ever try using one. Like others have said, it is not required, but once you try it you don't want to go back
    Quote Originally Posted by JVTrain View Post
    LOL
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    I don't know what everyone else thinks but I think it makes the testing much faster. No need to stop and swirl between each drop. Since no answered Madison Mikes question about adding all the drops and swirling after all were added I will wait to see that question answered before admitting my stupidity for swirling after each drop.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    I don't use it if I'm doing just one test--the chlorine, but if I do a few, OUT IT COMES!
  20. Back To Top    #20
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    And I've found that if you don't use it and don't manually mix well enough you may not get the change you should until the next drop. So yes, better accuracy is what I've seen.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
