Thread: How are we doing? Suggestions needed for new build.
    Been on and off the website trying to gather as much information as I can. Here is where I am at with our PB. How am I doing? Any suggestions?
    This is for a 18’ x 38’ x 26’ x 14’ L-Shape Custom Pool
    Custom 20 mil Liner
    1 – 8’ straight step – Fiberglass Granite blue
    Hand troweled vermiculite bottom
    Concrete collar Installation
    2’ radius reinforced custom corners Concrete
    A-Frame bracing
    Safety ropes and floats
    Stainless grab rail
    Stainless 3 step ladder
    Stainless steel escutcheon *Vinyl over steel step and bench combo add 2,800.00
    Bronze anchors
    Start up chemicals
    18’’ pool brush
    Vac pole
    Vac head
    Vac hose
    Test strips
    Leaf net attachment
    Deluxe test strips
    Deluxe solar cover
    Solar reel
    GLI custom PRO MESH winter pool cover
    1,000 sq ft of standard color concrete
    Concrete Filter pad
    Installation of pool, and filter with premium backfill and footer drain
    All 2” Schedule 40 pipe
    2 Wide mouth Skimmers
    4 – Clean water returns
    1 – Dedicated Vacuum port
    2 – Bottom Drains
    “Never lube” custom valves
    Pentair Intelli-Chlor Salt System w/18 bags of pool salt
    Pentair Quad 320 Cartridge Filter
    Pentair Intelli Flow variable speed pump
    Pentair 250 electronic Gas Heater
    4 - Pentair color LED Glow Bright in-pool lights
    Thanks!
    Re: How are we doing? Suggestions needed for new build.
    That looks fairly good. There is more detail than we often see.
    I suggest getting a larger heater. It isn't usually much more money, and it can heat the pool significantly faster. 400 is the most common large size. This is sometimes limited by your gas service, so it isn't always possible, but worth it if the cost isn't too high.
    I am a bit unclear on which filter that refers to. The "quad" filters are DE filters that come in sizes of 60, 80 and 100. There is a Clean & Clear Plus 320 cartridge filter, but it isn't quad. Assuming that is the C&C 320, a larger filter isn't required, but would be nice. Larger filters let you go longer between cleanings, which is always nice.
