Results 1 to 7 of 7
Thread: Recommendations for a PB in Eastern Panhandle, WV, MD, VA, PA.
    Schroedz's Avatar
    Apr 2014
    Martinsburg, WV, USA.
    87
    Exclamation Recommendations for a PB in Eastern Panhandle, WV, MD, VA, PA.
    I'm looking for recommendations for a PB in the Eastern Panhandle, WV, Western MD, Southern PA and possibly Northern VA.
    My pool is in need of a big remodel and I'm looking at getting it done asap.
    It needs new vermiculite bottom, coping replaced, 2 extra returns and of course, a liner and water.
    I've contacted over 20+ PB's/pool repair companies, 6 - 7 have got back to me and I'm left with 2 estimates, which I'm not too happy with...
    Frustrated to say the least...
    Thanks in advance.
    21,000 Gal, 16' x 36' Grecian In-Ground Vinyl Pool,
    Built 1981 ~ Reno/New Liner June/July 2014,
    Hayward Pro-Series 25" 300lbs Sand Filter With Zeobrite Media (SM2506T),
    1 HP Haywood Dual Speed Super Pump (SP2607X102S).
    TFT-100 & Speed Stir ~ Aquabot Xtreme Robotic Cleaner.
    Schroedz's Avatar
    Apr 2014
    87
    Re: Looking for a PB in Eastern Panhandle, WV.
    Anyone?
    Schroedz's Avatar
    Apr 2014
    87
    Re: Recommendations for a PB in Eastern Panhandle, WV, MD, VA, PA.
    Need help badly please
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Do you know anyone whose built a pool in your area recently?
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Casey's Avatar
    SW PA
    10,446
    Have you sat down and done a search or pool builders in your area?
    Can you tell us what kind of research you have performed to see what's out there?
    Mar 2014
    Annapolis, Maryland
    37
    Regina Pools is wonderful in dealing with vinyl liner pools. They are in Maryland, but I'm not sure how far out they travel. It's worth a call...you can google them!
    Schroedz's Avatar
    Apr 2014
    87
    Laceygirl.. No one has had one build or renovated near where I live, as far as I know.
    Casey, I've done the google search and then some. I've had some quotes but most I don't get a good feeling about the people and one retracted their estimate after I refused to let them use flex pvc on a main drain.... Crazy to refuse to let them do it, maybe? But I'm looking at $12k to $14K worth of work done, I want someone I feel comfortable with and can trust.
    Plops, Not sure if I can use them, they are 96 miles away from me but I will call and see what they say... I have had an estimate from Pro Pools in Hagerstown, MD. So I'm not opposed to using someone from MD.
    Thank you all for the help I do appreciate it.
