Thread: Another BBB success story
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Last fall, a hospital stay and recovery time kept me away from closing my AGP. It resulted in a dark green mess this spring. Well after 2 weeks of keeping shock levels constant, I can finally see the bottom of the pool. Current readings FC:17 CC:2 PH:7.2 CYA:40. Looks like I'm close to the end and sure feels great!
    6423 AG Intex 18 x 48 Intex 2100 GPH Sand Filter Pool Pump TF100 test kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Another BBB success story
    Well done...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Casey's Avatar
    SW PA
    10,444
    Congrats on getting her back up and running! Keep SLAM'ing til that CC comes down and brush! Brush! BRUSH! your pool!
