Results 1 to 11 of 11
Thread: How do I chlorinate for vacation?
    Jul 2012
    Forest, VA
    79
    Ok. Pool has been open for several weeks. All the numbers are within range.
    Last test:
    FC 6
    CC 0
    Alk 90
    CYA 50
    pH 7.4
    I am going on vacation for 8 days. What is the best method to use to chlorinate the pool? I thought about using 3" tabs in my chlorinator on low to med. Any thoughts? I know this will bring the CYA up a little bit. My pool gets a lot of sun. If I use the tabs, how many would be sufficient for 8 days?
    Thanks in advance for your replies.
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: How do I chlorinate for vacation?
    Any close neighbors or friends that can dose it up for you a bit while gone? If not, take it to slam level for your cya and put in a floater full of pucks. Covering will also help.
    Aug 2011
    Southern California
    188
    Back when I used a floater, I could get 5, 3 inch pucks, into it. They would last about 7-8 days on a medium (half) opening. Check your weather forecast for that week just before you leave and adjust your opening for that. Pack it full and drop it in the water as you walk out the door. If you feel it's not enough, you could always bump your FC a bit the night before you leave to help out, but you should be OK.
    Have fun.
    Oct 2013
    Chapin, SC
    1,141
    Last year, I put 4, maybe 5 tabs in a floater (you probably can get by with fewer) and poured a couple bottles of 8.25% bleach in the pool just before I left. My fc was still 4.0 when I got back 8 days later, and the tabs weren't completely dissolved. Good luck with yours!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    If your chlorinator is inline - that's the way to go and it won't raise the CYA that much in 8 days. Will the pool be uncovered, on a timer then, or running nonstop? If so then evaporation/water level/power outage are the only issues to worry about, perhaps a neighbor could call and take instruction should any of this come into play... Perhaps fill pool up to top of skimmer before you leave to account for possible evaporation.
    Casey's Avatar
    SW PA
    10,453
    Bring to SLAM and cover with a solar cover and use pucks in your chlorinator. You should be fine. Good luck and let us know how well the pool faired while you were away.
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Jun 2011
    Knoxville, TN
    19
    We have an inline chlorinator -- so I usually add extra water the day before we leave and then I'll bump chlorine (with beach) to the high end of our TFP limit (around 6-7 FC) Then I put around 6-9 pucks in the chlorinator. I run the chlorinator on low while we're away. Usually 4-5 pucks will last 9 days on low and so I always throw in a little extra because our pools gets tons of sun and tons of debris (plant and insect/animal). I will say we keep the CYA on the very LOW level for a vinyl pool -- so I don't worry that much about the pucks.
    21K gal, IG - Free Form, Vinyl (replaced in 2012) with Hayward S-244T Sand Filter, Rainbow 320 Chlorinator (installed in 2015 to replace Hayward 220 Chlorinator), in process of installing Liquidator
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Pysiek View Post
    That looks interesting. Maybe next year...
    Isolated Spa - 345 Gallons
    38,449
    Quote Originally Posted by Utlmnop View Post
    I do not follow why the type of pool has any relevance to your CYA level?
    Jun 2013
    Newcastle, Oklahoma
    508
    for 8 days, pucks is your best bet. if we go for just a couple or 3 days, I bring pool to shock level or above and cover, otherwise, Ill have to go buy a puck dispenser.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
