I have a 24' round above ground pool that I just converted to salt water. Been running about a week now. I did a check with the test strips and the results were :
Total Hardness: Very Low (Less than 100 PPM)
Total Chlorine: OK (3 PPM)
Free Chlorine /Bromine: OK (2 PPM)
pH: Low (about 6.8)
Total Alkalinity: Very Low (40 PPM)
Stabilizer: Very Low (0 PPM)
My questions are:
Do I use the same chemicals at he same rates (always guessing with chlorine) with a SWG as I did with Chlorine, or is there different chemicals required for salt water pools?
Any suggestions on what and how much to add without affecting the numbers that are in line?
Thanks
pH: Low (about 6.8)
My questions are:
Thanks
