Thread: acid on cover?
    Jul 2012
    Whidbey Island, WA
    397
    acid on cover?
    pool is covered so to add acid must raise the corner of the cover but it then sags and some of the cover is in the water
    acid is 31% acid and is diluted 1pt in 3gal or 1pt in 25pts
    1/25*31 is 1.2% acid
    now 1.2% becomes way less as soon as it hits the pool but...
    is there any way this could hurt the cover?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: acid on cover?
    What are your test results and what is your pool temperature?
    My understanding is that at very cold temperatures, the effects of high (or low) pH are much, much less. Most of the pH change is due to the temperature change and not due to an underlying chemical change to the water. Basically, leave it alone until you open it up.
    Jul 2012
    Whidbey Island, WA
    397
    Re: acid on cover?
    Quote Originally Posted by Smykowski View Post
    all within troublefree ranges save pH 8.
    pool temp 53 degrees
    thank you
    30,403
    Re: acid on cover?
    I think your dilution technique is fine and I doubt it will hurt the cover. Are you running the pump so you get good distribution?
    Jul 2012
    Whidbey Island, WA
    397
    Re: acid on cover?
    thank you
    I am running the pump when adding the acid, on Timeout, runs 3 hours than returns to Auto
